Digitech whammy preset controller
Started by Gila_Crisis, June 01, 2007, 03:37:35 AM
Gila_Crisis
Hi,
i have a whammy 4 and i really like it. but now seeing it has a midi plug, i was thinking if a can build a stompbox to go up and down thru all the  preset.
it that possible? are there any schem somewhere?
thank you
Austin73
not sure if its any help but I use my BOSS GT3 or my Behringer FCB1010 to control my Whammy , I also find the pedals a bit stiff so I use the exp pedals on the other two as I can switch which way the pedal travels just check the manual for the midi numbers its quite easy
Aus
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
Austin73
not sure whats on this site but has a few midi projects that might help
http://www.musicianstechcentral.com/library.html#diy
aus
Gila_Crisis
it would be nice somithing like hte tech21 midimouse
or something like that: http://www.masottiamp.it/custom-mstomp.html
