i need a buffer...but a specific type...
Started by jonathan perez, June 07, 2007, 01:25:14 AM
jonathan perez
ok, ill try and word it as best i can.
my WH-1 whammy only sounds good after a Boss distortion (or metal zone), and through the loop of a marshall 2205 amp. i assume the buffered output of the Boss pedals has a good say so on that..
what type of buffer could i build so that i can permanently use my whammy in my 6505+ loop?
hendriko
have you tried one of the buffers that come stock in the dunlop wahs of today?
that might work
Gimme gimme shock treatment.
jonathan perez
no, i dont have any that arent true bypassed  :D  ill try leaving the noise suppressor in front, MAYBE thatll work... but i wonder, is it the input AND output that are buffered?
rockgardenlove
On the wahs?
Input.
So they don't suck quite as much tone...
jonathan perez
so what is it on the metal zone and the JCM800 2205 thats buffered?
RedHouse
They both use OpAmps.
Sometimes OpAmps are your friend, we often try to avoid them ...but.
The Marshall Effects loop uses the TL072 in it's loop, and the Digitech likely uses one similar also.
