Wiring DC jack and battery.... Help I'm new to this.
Started by demonstar, June 07, 2007, 04:40:02 AM
demonstar
Hi, I'm just about to start making my first electronics project. I chose a distorion pedal and I've all planned and I'm ready to go for it except for one thing. I found the wiring diagram for it a I'm unsure as to whether if I put a battery and the DC jack on at the same time would I provide 18V to my board and damage it or will the battery cut out of the signal chain. I would like it to cut the battery out the signal chain when i plug the DC jack in, like commercial products. Is this easy to do  and if so how would I do it? Any help would be much appreciated!
This is the wiring diagram. I'm doing option 5. With the 3PDT, LED, Battery and DC jack.
http://www.tonepad.com/getFile.asp?id=76
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
MartyMart
If you follow the wiring diagram you'll be fine, circuit is battery powered and then gets "cut off" when a
9v DC plug is inserted into the DC socket, there's a sleeve connection that's "floating" and the barrel of the
DC jack touches and pushes it away - disconnecting the battery.
MM.
demonstar
  I'd try verifying everything especially including no shorts to PS under all conditions before applying voltage.
