Negative Ground Fuzz?
Started by mattpocket, June 14, 2007, 05:21:59 AM
mattpocket
Is there any -ve ground fuzzes out there? I got a mixed batch of germaniums that are itching to be used... there are a lot of PNP, a few ac128s, and some other cool ones, I will test them all for hfe and leakage, but I need a circuit to put them in...
Can I use PNP trannies in a -ve ground pedal? My harmonic perculator has a PNP in it and its negative ground...
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
GREEN FUZ
  And use or steer right past the first one. Tha's a Neg Gnd PNP FF...expect possible intractable problems or working FF.
  I suggest wiring up a PNP Pos Gnd. FF, tweeking on that some with a battery, then using a MAX1044 to reverse PS polarity so that the FF can be put into use with other Neg Gnd effects.
  I get great results and improved temperature stability, using hybrid EZ Face [Ge/Si] fuzz faces...using - or  ground [NPN] or + ground [PNP] supply.
GREEN FUZ
QuoteAnd use or steer right past the first one.
Yes, I should have mentioned, this configuration is the source of countless " why is my fuzz face motorboating/squealing/farting....? " posts. Sometimes it works, sometimes it doesn`t.
mattpocket
There are no "real" fuzz face designs that have negative ground? And the only way around it is to use another circuit to reverse polarity?
Thats a drag...
Thanks anyway! ;D Think I will be trying something of my own design...
Matt
  make an NPN neg Gnd FF...
  Axis face for instance.
  Or Ge/Si hybrid.
  Or Ge FF..
  I copped a fine tune on a hybrid NPN -gnd., that's what I'm using.
markm
Quote from: petemoore on June 14, 2007, 02:55:30 PM
  Or Ge/Si hybrid.
  Or Ge FF..
Agreed.
It's really a pretty simple operation.
