How to make 9V Electric Mistress True Bypass with LED ?
Started by Nuts, June 15, 2007, 09:47:28 PM
Nuts
zarathustra
There's a good summary of how to do this in the FAQ, here.
You'll need a 3PDT switch. Use two of the poles for the bypass and the third pole for the LED. Good luck!
Nuts
I did it, the true bypass works, but the Led doesn't turned on  :-\
When I plug in the the power, while the pedal is on, the led light up for a second
can you please help me ? I'm desperate.
nikStomp
Hello? post some photos of the board? what have you done exactly?
