Big Muff Tri Help
Started by tomcor33, June 27, 2007, 02:19:34 AM
tomcor33
This is a great forum. I have already built a Fuzz Face , Red Llama, both work great. I am working on a Big Muff Tri from Andrew Carrell's Perfboard layout. Has anyone else built from this layout? I have traced all connections 3 times carefully. Maybe there is a problem with this layout? Probably not but I just wanted to know if anyone else has built from this Layout? Been trying 3 days to get it working. I get low volume on the sound and the drive and tone is not right.
jlullo
tom,
take a look at the sticky "what to do when it doesn't work"....
if you post your voltage readings here, we might be able to help you out!
jonathan
m_charles
I've built a few muffs, not from that layout.
you need to a/b with a regular schem, even if you're still learning to read them. That will solve your problem quick!
1. check grounding, make sure everything has a ground that needs it.
2. make sure your trannies are faced the right way.
3. There is a tri schem going around that shows 10k pots. If your layout shows 10k pots, its wrong. You need 100k.
all this and what jonathan said in his post...
good luck.
chuck
theehman
#3
Make sure the trace from VOLUME 1 is connected to ground.  That doesn't seem to be very plain in the layout.  R23 should connect to the other side of C13.
Ron Neely II
fx schematics and repairs
tomcor33
#4
I am using 100K pots. The trannies are orientated correctly. All the grounds are correct. I did find that I did not have Vol 1 connected to ground. I also checked R23 to C18 they are connected. You were right. But now I have no sound at all coming out of output. My voltages are:
Q1- E .020  B .66 C 1.80
Q2 E  0       B  0   C 8.14
Q3 E 0        B  0    C .036
Q4 E  0        B  0    C 8.14
I am using 2N5088 's
I tried using 2n3904 's Just in case I blew a transistor.
I will keep rechecking my connections. It has to be somewhere. This is kind of a tough build on small prefboard. I have been reading schematics for years. I will try to trace voltages from schematic next.
boyersdad
If you're getting 0v to one transistor, that's where to start looking. Trace the voltage path back til you find out why there's no juice there.
I like amps etc.
ambulancevoice
did you solder the transistor to the board or did you use sockets?
tomcor33
I used sockets for the Trannys. I just went through the regular schmatic carefully. The Perfboard layout I was has 3 or more errors.
I think I will start over again with a larger perfboard and use the Tonepad layout instead.
m_charles
If you perf it, I highly reccommend using the Radio Shack (or other brand) perf with the copper trace around each hole. You'll end up with a more solid circuit, and it will be easier and neater.
Also, you said you're cool with reading schems. For my first Big Muff on perf I did my own "literal" layout, meaning I layed the parts out as much like the schematic (from GGG, but it wasn't a triangle) as possible. I used a big enclosure so I was able to do it this way. I'm very visual so it made it much easier for me. just a thought...
also purley opinion, I'd go with the 2n3904's.
keep us posted!
chuck
tomcor33
Still need help..
I started all over again on a new perfboard and followed the layout of the schematic. I have checked all grounds, battery connections, jack connections, pot connections. I am not getting any sound at all. I am using 100K pots also. I also went through the schematic one point at a time. All my gounds are hooked together also.
Here are my voltages.
Battery 10.12
Q1 C- 5.56    B- .81  E- .19
Q2 C- 4.63    B- .68  E- .04
Q3 C- 4.44    B- .63  E- .02
Q4 C- 10.12 B- .002 E- .001
Any ideas?
Thanks for any help.
Beros
I've built it too and, like you, couldn't get it to work.
So if you find the errors and correct them, could you please post the corrections to Andrews layout here?
I've been probing mine, and it seems to work up to around the second trannie.. But then again I am still new to the whole probeing thing, and haven't had the patience/time/<insert lame excuse> to go through it properly.
Man ska inte ligga med lik
tomcor33
What I found in the Andrew Carrell Perfboard layout. Tone 1 and Tone 3 are reversed. Also R23 and C13 should be hooked in paralell with Collector and Emitter  as per Tri schematic.  I ended up starting all over from the original Tri schematic. The Carell perf layout is somewhat confusing. I suggest you go into the DIY Maker program and print out just the PCB layout for this version. Makes it easier to see hidden connections on PCB. Also all crossed bold lines should be connected. After finding the errors with R23 and C13 I tore my perfboard apart.
Beros
markm
I can verify that mine works.
I built it and I've had many PM's about it and it works fine.
You fellas are perfing this one?
Beros
Quote from: markm on July 05, 2007, 12:19:03 AM
I am. Just finished the board. Just some wiring left to do, then I'm all set... I hope my recycled components survived the transplantation... And man I'm getting tired of perfboard.
Althoug it seems simpler than going to the store to buy etchant, a drill, drill bits, etc..  ;D
markm
Once you get set up to etch, there's not much more than etch and build.....
Hey, debugging is easier!  :D
tomcor33
#16
Mark,
I was going to use your layout it looked good I even traced the schematic with it. I decided just building like the schematic would be easier. Next time I will etch my own or buy a pre-made board. I did find 2 resistors I reversed on my new layout. I now get some sound, but low volume. The vol connections seem to be backwards, and the tone and sustain only have a small effect. I will get some more voltage rteadings again. Also I will build a signal probe to trace circuit. This is a learning experience. All though I have done electronics since I was a kid. I also use to own a VCR repair shop for 6 years.
I had a whole bunch of effects I sold before I had schematics.
Memory Man worked fine.
Distortion + Script
Guild Foxy Lady.
Univox Superfuzz
Heathkit Fuzz I built
EH Bad stone
Mutron III
Original Tube screamer
67 Telecaster in pieces but whole
Blue Box
Phase 90
Silvertone 1451 amp
markm
Quote from: tomcor33 on July 05, 2007, 01:50:02 AM
Distortion + Script
Guild Foxy Lady.
Univox Superfuzz
EH Bad stone
Mutron III
Blue Box
Phase 90
Silvertone 1451 amp
:icon_eek:
Wow, that's some real nice stuff.......I love Teles.
tomcor33
Update:
I got the Big Muff Tri working now. I went through the schematic and layout again and found 2 errors. That did the trick. Next time I will just order a pre-made PCB. Sounds great! I am using 2N5088 trannys. Vintage Tri schematic. Now if I can just get the Arion SAD-1 working I bought on Ebay for $15 plus shipping. That is in another post.
tomcor33
To get this working I used the Tonepad Schematic here.
http://www.tonepad.com/project.asp?id=3
