Rangemaster set boost, control tone?
Started by msurdin, June 30, 2007, 05:16:50 AM
msurdin
I am trying to build something like the rangemaster on the rangemaster board from GGG. What I am wondering is if i can have the boost pre set inside but then have a outside tone. I just want it to go from bassy to glassy.
I tried installing a tone control once but it had massive volume loss. Is there a way to do this and have no vol loss?
Thanks alot!
Matt
blindsjc
I used the obsidian tone control with little signal loss, I think that
1M resistor make it. So, take a look, After final .1uF capacitor:
http://diystompboxes.com/analogalchemy/sch/obsidian.html
msurdin
I'm trying to make this more like the bsm or booster. How would I wire something like that to the GGG rangemaster board?
soulsonic
You could do the kind of tone control I've seen where you have a fixed small value input coupling cap and then a pot that lets you "sweep" in a larger cap in parallel with it. This would let you smoothly adjust it from a treble boost to a full boost. I forget which circuit it was I saw that had that, but I really like the idea.
blindsjc
I think that it will make things clear, dont remember where I got this
image and dont I dont find it again in layout gallery, but was there:
http://server4.pictiger.com/img/1109220/picture-hosting/big-muff-tone-control-pcb.gif
Just add at the end of circuit and play with values. You can use duncans tonestack
calc and see the tone curves before build: http://www.duncanamps.com/tsc/index.html
So, a lot of things to play with this sunday...
msurdin
do i have to have a board for that or can i just put the caps-resistors straight to the pot and on to the wires?
Can I jsut replace to tone pot with a internal trim pot? Do those have 3 solder points like reg pots? Can you reccomend a good kind?
Matt
