Modding the TS side on a route 66...
Started by pott, July 04, 2007, 09:01:35 PM
pott
So far I've changed the dioded for 1N4002s and the IC for a TL072... but the pedal still has too much of that high mid spike for me. The bass boost is really cool though.
Anyway on a TS/SD1 circuit, if i remember right the main culprit is a .022uf cap right..? Where is that little bugger on the Route 66? I haven't been able to look around, though I'm still a relative noob...
Thanks a lot if you can help me!
theblackman
they probably use a different value than 0.022, take a look at _where_ the 0.022 cap is on a TS (in the schematic) and try and find the same one on the route 66.
also look at '"Refine" your pedal and smooth the tone out' on the following page.
http://www.diystompboxes.com/wiki/index.php?title=Simplemods#Simple.2C_Easy_Mods.2FTips_.26_Techniques
Bought: zvex woolly mammoth, octane 3, moogerfooger ringmod, frostwave resonator, boss sd1, ds1, dd6
Built: big muff, green ringer, tremulus lune, the crank
Planned: harmonic percolator, pt80, shin ei.
pott
Wow cool website thanks! I'll do that once I get back to the Burgh. I'm guessing I'd need to find an easy landmark such as a pot's lug and trace back from there using the schematics?
