Gain Pot Question... adding one
Started by Barcode80, July 11, 2007, 01:07:26 AM
Barcode80
I would like to add a gain pot to the Firestarter OD. Here is the layout I'm using:
http://aronnelson.com/gallery/album120/FirestarterPCBLayout
I tried just throwing a pot on the input, but i got no signal, so i assume the load is too high to pass. any thoughts?
Dragonfly
the input should work fine...does the layout work when you ditch the gain pot ?
a different (and better) gain pot would replace R4 and have C3 coming off lug 2 to ground...see "Fuzz Face" for details.
Barcode80
hmm, yes the layout works fine with no gain pot on the input (guess i should mark it verified!) so do you mean something like this?
Barcode80
Also, say i wanted to add a BMP tone knob. in that case, lug 3 of the tone knob would go to the volume lug 3 pad, lug 2 of tone would go to lug 3 of volume, lug 2 of volume remains output, and lug 1 of both goes to ground, correct?
