Help cloning this fuzz pedal Please
Started by limlam, July 12, 2007, 05:10:55 PM
ambulancevoice
GREEN FUZ
It`s in that area along with another resistor that I can`t quite place. Bottom right-hand corner. More photos please.
Limlam, to finish this off we need any markings, letters , numerals. Can you write down what you see and put it against the corresponding component.
R= resistors
C= capacitors
Q= transistors
Don`t worry about the striped resistors,I should be able to work them out myself.
ambulancevoice
GREEN FUZ
I haven`t put it on the layout because I can`t quite make out where the pins are going, that and the carbon-comp resistor beside it.
Please don`t hurt me Ted.
ambulancevoice
jaytee
I think it might be something like this
aron
That looks familiar.... tone bender???
jaytee
Yes looks pretty much tonebender 'inspired'. What's the idea behind the diode? Should it be the other way round?
oskar
Quote from: jaytee on July 14, 2007, 04:52:21 PM
..... What's the idea behind the diode? Should it be the other way round?
No, the diod sets up the voltage for Ge1's bias.
oskar
Quote from: oskar on July 14, 2007, 06:16:13 PM
...so... yeah, it should be the other way around, shouldn't it?   ???
My breadboards full right now...    :P
ambulancevoice
nice job man
now just gotta get the values
jaytee
Looking at it again I think it's a resistor not a diode. Might even be 1.8k. It's almost a bogstandard tonebender. I think the pots are 100k.
ambulancevoice
ambulancevoice
to bad its neg ground
mmmm, im gonna have to make a bi polar supply
wait, i just had a though
what if you did this
chris_d
Aw. And i thought i was being all clever when i put my DOD-250 in here:
Oh well. Everything's been done, usually hundreds of times, before! :D
-chris
soulsonic
Quote from: ambulancevoice on July 15, 2007, 12:59:08 AM
What do you mean? It's positive ground.
The circuit you drew won't do anything.... it certainly won't get you a negative supply from a positive one.
You can use one of the basic MAX1044 circuits to get a negative supply from a 9v. Real easy. Or you could just use a battery and not even have to worry about it.
ambulancevoice
eh, ill just make a bipolar power supply
soulsonic
ambulancevoice
so i can have a + 9v supply for my negative ground pedals and a - 9v supply for my positive ground pedals
