Tape Player Distortion
Started by 12milluz, July 15, 2007, 10:07:53 PM
12milluz
I've heard a little bit about this...can anyone help me with the specifics of how exactly to do it?
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
Rodgre
Brad Laner of the band Medicine used this as his main distortion (he used a 4-track, if I recall) and I once saw a band in NYC where the bass player used a cassette deck for his fuzz. Pretty neat. I've done it a few times with tape decks and other devices with preamping capabilities for interesting extreme fuzz.
Basically, you get a standalone cassette recorder, plug your instrument into it. Put it in record-ready mode and crank the record level. Plug it into a volume pedal or something that will at least give you the ability to turn down the master level. There ya go.
Roger
12milluz
Thanks! Now I've also heard of doing it with a portable cassette deck. Anyone know the specifics of this?
ambulancevoice
yeah, all you do is remove the tape head and wire a input jack in place of it, and use the headphone jack as an output, or wire your own jack
i attempted this but it didnt work and i gotta do it again
but one tip, the older the tape deck, or walkman, the better
try and avoid a smd ones, and get one that uses traditional components
here is a tutorial on making one
and yeah
http://brokenpants.com/?page_id=211
and some notes and mods
http://necrosensual.com/bent/walkmandistortion.txt
12milluz
