LED and power/grounding issue?????
Started by powerplayj, July 28, 2007, 02:18:49 PM
powerplayj
Anyone experience issues with Digitech pedals in regard to powering them?  I have a DigiDelay in a chain with a Boss GE-7 and each time I plug in the daisy chain adapter to the Digidelay, the LED of the GE-7 comes on.  The same thing happened to a Dano Fish 'N' Chips when I placed it in the chain as well.  The adapter is a Visual Sound One-Spot so no issues with overdrawing current are likely.
I'm not sure where to start troubleshooting.....switch, DC jack, etc.
Any thoughts?
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
powerplayj
On second thought, it may have more to do with the GE-7 in which I just modded.  When I connect both the GE-7 and Digidelay to the daisy chain, I can plug in a cable to the GE-7 input and as soon as I touch the other cable end to the Digidelay output, the GE-7 LED comes on.  Should I assume there might be a solder bridge somewhere connecting the LED ground and input ground of the GE-7?
next build(s): ???
