What's wrong when ALL my pedals pop?
Started by YouAre, July 30, 2007, 11:43:06 PM
YouAre
Ok, i've been busting my ass for the past week, re-wiring my overdrive (byoc ts808 board) 10 different times to eliminate a switch pop. With an LED, there is a loud pronounced pop.
-I've tried the old bypass here http://www.diystompboxes.com/beginner/circswled.jpg , pops
-then instead of switching the power to the LED, i switched the LED to ground. effect works, still popped
-then i tried the input grounding style, like most new GGG projects, the BYOC kit wiring, the OLC kit wiring (http://www.olcircuits.com/support.html , go to doc # 2), still pops
Then i tried the two different styles of wiring, but without the LED. Not as pronounced of a pop, but more of a click.
Discouraged, i put down the soldering iron and plugged my guitar into my tuner (korg dt-10bk) and....i'll be damned if i heard a little click out of that too! so i got some other non-diy pedals. A mxr phase 90 (not vintage), digitech digiverb, and a CMAT mods ts808. The cmat pedal obviously had the same issue as my overdrive. But the 2 commercial pedals clicked too! Not as loudly, but you could hear an audible click!
Now i just have one question. WHAT THE HELL?!?!!?
Here's the important information. Amp is a fender prosonic head into a 212 cabinet. Cables to and from pedal are either cheap 15foot cables i bought from guitar center, or george l's patch cables. The power supply is a godlyke Powerall.
What do you guys think it could be. Also, i had the same issue at my gig last night. The overdrive popped, and i had the input grounded style wiring.
AH!
thanks,
murad
jonathan perez
was is so loud that anyone would be like "what the flying pig was that?!" or was it just "only i, the guitar player, will notice."
There are only two reasons effects pop when switched.
1. You're switching between two different DC levels. Find where the DC is not blocked and block it, or eliminate the leak.
2. You are coupling in the sudden change in power use when an effect is switched on or off through power, ground, or parasitic capacitance.
Number 1 is much more common.
Processaurus
Is your amp putting a DC level on its input?  So that when you switch to a pedal whose output was at zero volts, there is a pop as the effect output adjusts to the non zero DC level?  You could tell quick by sticking a cord into the amp and testing the DC volts between tip and sleeve.
YouAre
Quote from: thebattleofmidway on July 31, 2007, 12:11:01 AM
The TB pedals pop loud enough for people to notice. The buffered pedals click enough to bug me and tell me "something is not right"
Quote from: R.G. on July 31, 2007, 12:20:27 AM
When you say find were the DC is not blocked/leaking, where would i be searching for that? In the pedal? In my Powersupply? Its popping in ALL my true bypass pedals, so i'm thinking i got a serious issue! Also, if I need to poke around my pedal, how would i do that? And how would i block the leak?
Quote from: Processaurus on July 31, 2007, 04:25:41 AM
I turned on my amp, stuck it into a mono jack, and busted out my multimeter. I was getting .2 mv, totally negligible cause my DMM reads more than that when it's even just idling.
Think it could be the powersupply that needs to be replaced?
One of the somewhat counter-intuitive side-effects of the current true-bypass frenzy/cult/zeitgeist is that if you have a bunch of TB pedals in series and one of them somewhere has a "hanging cap", switching another pedal somewhere else can still produce a pop.  Imagine we have 5 pedals in a row and pedal 1 has a hanging cap on its output. If all the otherpedals are off and I switch any single one of them on, there will be a brief instant where that cap is disconnected and then reconnected.  Of course, since the pop is occurring when I'm switching one of the OTHER pedals, I assume that the problem is with them, when it it really isn't.
I might also point out that Boss pedals have a hanging cap on their input since they assume all switching will be done internal to the circuit, so the cap will never be left hanging or unconnected once you plug in.   You get used to hearing a slight pop at that point, but you never hear a pop thereafter when you engage and bypass, so you figure everything is copasetic.  But it isn't.  The irony is that if you try and get Boss and homebrew TB pedals to play nice with each other, each time you engage or disengage the TB pedal just ahead of the Boss pedal (or even several ahead if you have, say, a couple of homebrew distortions followed by a Boss Chorus), that input cap is momentarily disconnected then reconnected.  It's not a BIG cap (Usually .01uf, right?), so the pop shouldn't be huge, but it's there and just about anything can sound annoying if its pumped through a 4x12 stack.
Really, you need to check everything you own and stick terminating resistors on the front and output, even if the pedal normally works just fine on its own without one.  The goal is to get TB and FET-switched pedals to "play nice" with each other.
YouAre
Quote from: Mark Hammer on July 31, 2007, 09:15:08 AM
actually....i don't even think its that the pedals aren't cooperating with each other nicely either. Every pedal i tried popped when it was just guitar to that one pedal to amp. Odd! I guess i'd rather address the TB pedals with LED's first cause....they annoy the shit out of me most. Pops so loud that it could actually interfere with the song. The BYOC board has a 4.4m (2x 2.2m resistors in series) pulldown resistor at the input. Not sure about the output.
after more testing, i've come to realize its like a microphonic pop. It could be that the TB pedals have a louder click when you hit the switch, so their pop is louder. I'm trying to find alternate cables to test if its a crap cable.
YouAre
holy @&%^#%&^!!!!!
i get a noise.....if i flick my cable....wow....
Yeah, what do you think could cause this?
Some cables are in better shape than others.  Beyond that, some plugs and jacks make better and more consistent contact with each other than some others do.  Remember, it's all metal, and metal was rarely made to go boing.  More often it bends and returns to shape more or less, but stays a little teeny tiny bit bent out of shape.  The first phone jack on your pedal-board, and the plug going into it, as well as the guitar jack and plug, should be the best quality you can afford.  The other plugs and cables on the board don't get moved around quite as much.
YouAre
Man, its upsetting that i've tried several different variables, cables, battery vs. power supply, different pedals, i'll always get SOME noise. I guess its my DIY pedals that bother me the most cause i built them and i want them to be of the best quality.
So what are the ways to minimize LED pop on  TB pedals? I've got the input grounding style wiring, Input Pulldown resistor....what else?
Well perhaps we might need to know exactly what your signal path is from guitar to amp.  I certainly don't want to encourage "here's MY rig" bragging, but sometimes there are interactions between things that are inadvertently overlooked, so a bit more detail will help.  If you can list the sequence of things your signal goes through and which are true-bypassed, that might help.  For all we know, it could be your amp.
Just curious - you haven't done anything recently that might have offended a minor deity, have you?
:icon_biggrin:
Gus
Was you testing, guitar- one effect- prosonic?
Did you try another amp?
  If you did and the pop went away
Did you change the tube that is connected to the input jack of the power amp?
Did you try a battery in the effects?
David
Quote from: Gus on July 31, 2007, 02:28:33 PM
YouAre -
There are good clues here.  Gus asked the big question before I could.  Did you run all these tests with the same guitar?  I suggest you repeat with a different one.  Also, the battery test is another biggie.
R O Tiree
I have a guitar lead that seems to have a couple of mV permanently hanging around on it. If I use that one, my pedals pop. Use the other one and they're golden.
There's a circuit snippet at AMZ here: http://www.muzique.com/lab/led.htm that does a good job of limiting LED inrush current which can be a source of popping.
Aside from that, what Mark Hammer says above is sound (sorry - bad pun) advice.
...you fritter and waste the hours in an off-hand way...
Quote from: R O Tiree on August 01, 2007, 03:49:20 PM
Could have been worse.  You could have said I hit the nail on the head.  Now THERE'S one I haven't heard over the last half century!! :icon_lol:
YouAre
ok so i've been testing a bunch of different setups. The Most obnoxious pop is when i use the DIY overdrives with an LED. I'm going to try AMZ's led popping fix again and see if that does something. As far as the other buffered pedals, if i turn them on and off repeatedly, the click dies down.
So this brings me to another issue. True Bypass....i think i'd  like to try something else! Does anyone have the layout/schematic for a simple buffered bypass using a non-latching switch? I'm sure one of jack orman's buffers can be retrofitted into a bypass. I ask if there's a non-latching switch because that mechanical CLICK seems to carry into the obnoxious pop. Anyone ever do that?
grolschie
Some true bypass with LED designs say to use a bigger resistor with the LED to avoid popping sounds.
YouAre
Quote from: grolschie on August 01, 2007, 05:08:16 PM
so there's a correlation between brightness of LED and popping?
GREEN FUZ
It is curious that it still seems to happen no matter how you configure your setup. You say, even when reduced to a single pedal to amp, no matter which pedal it is, the popping still occurs. Have you tried setting up in another environment i.e another house/rehearsal room/garage whatever? Perhaps there is some other factor causing the effect.
I`ll risk incurring some scorn by mentioning the phrase "Dirty electricity". I don`t know enough about it but perhaps someone who is more knowledeable could say whether this might be an explanation.
