Does anybody here know the pinout + other uses for Mullard OC81D please?
Started by luap77, August 03, 2007, 05:11:55 AM
luap77
Hi all,
I've just managed to dig up some Mullard OC81D transistors (metal case version) and am thinking tonebender. I'm not sure of the pinout.....could anybody here help with this please?
Thank you
P.S. Do any other stompboxes use OC81 transistors?
Paul E
Toney
  Looks like the OC81"D" suffix is a very low HFE variant. Up to 25.. that seems awfully low!
If this is what you have... they may not be very useful.
Here's a link http://vintageradio.me.uk/info/germanium.htm
Having said that, there are no rules with Ge's -test them and see!
King Tubby
Quote from: Toney on August 03, 2007, 05:35:08 AM
The > before the 25 actually means "greater than" :*)
Sometimes there's a white or red dot on transistors like these which usually indicates the collector.
luap77
THank you. What about the order of the pins on OC81D please? Collector (red dot) then which is B and E? These are rare transistors and I don't want to damage them. I've extra, so am wondering if any other pedals specifically used OC81 germaniums?
BTW I have a collection of about 3000 Ge transistors, so I am aware of substituion based solely on hFE (and no other characteristic) and also the mojo aspect, however, several people here have commented in the past that OC81D has a specific sound in the tonebender that isn't quite matched by others.
Cheers.
Paul E
King Tubby
It should go C (indicated by a dot) then B E, this is what i've found it to be on other OCXX transistors but search for a datasheet just to confirm!
I dont recall any other pedal specifically using OC81Ds
They should be alright to use in most germanium PNP pedals like the fuzz face and the Rangemaster and their numerous variations.
Use sockets, less chance of heat damage from your iron  :icon_smile:
SISKO
To all the OCxx Ive got the pinout was C red dot, then B and E
Hope it helps
--Is there any body out there??--
luap77
Yes, this does help. Thanks very much to everybody that replied.
Paul E
momiel
The TONE BENDE MK II uses the OC81D!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The devices with them are said to be the best ones....
I'm sorry but my English sucks!
Freaking with real fuzz boxes...
