trimpot
Started by Clubman35, August 03, 2007, 07:08:51 AM
Clubman35
Can a pot be used in place of a trimpot (if it's the same value)?
Thanks.
Timebutt
Sure, will not be a problem :)
Completed Projects: Gus Smalley Booster, Modded Russian Big Muff, Orange Squeezer, BYOC Vibrato, Phase 90
CGDARK
For testing purposes is OK, but for a permanent build you will have another control to deal inside or outside the enclosure.
CG
GREEN FUZ
There is no problem having it as an external control if there is some parameter you want to access easily. An example would be the Bias control on the Analogman sunface.
Clubman35
Quote from: GREEN FUZ on August 03, 2007, 08:00:16 AM
That is exactly why I want to do this. Thanks for all the fast responses.
