looking for a PCB mounted 2PDT footswitch...
Started by blanik, August 06, 2007, 08:28:55 AM
blanik
i'm fixing a MXR microamp for a friend (the footswitch broke after a couple of years of abuse), when i opened the pedal i was surprised to see the switch directly soldered on the pcb (the other components aren't SMD)
i've checked SBear and PPPlus and can't find those switches...
R.
smallbearelec
Many commercial pedals use the PC-mount version of either the Taiwanese X-wing or the Alpha. The X-wing PC mount is not available from retail sources in the U.S. yet. Mouser does carry the PC-mount version of the Alpha switch, their p/n 107-12011F-L. In time, I may add these to the SBE Stock List.
Regards
SD
Darren N
blanik
Quote from: Darren N on August 07, 2007, 02:33:41 AM
I thought the new MXR pedals used these ones:
http://www.smallbearelec.com/Detail.bok?no=80
nah, here's a pic of the PCB, you can clearly see where the switch goes...
MarcoMike
Only those who attempt the absurd will achieve the impossible.
blanik
#6
Quote from: smallbearelec on August 06, 2007, 09:31:49 PM
Regards
SD
i didn't find this part number but i found this one
#107-SF12011-L
i checked the specs and measured the holes and it's a perfect match...
smallbearelec
Apologies...I was missing the "SF". 12011F is RoHS-compliant; 12011 is not. Either one should do here.
SD
