Switching between two effects
Started by moro, August 10, 2007, 01:03:53 AM
moro
If I want to put two effects in the same enclosure, is this the correct wiring? (I'd have a 3PDT for effect on / bypass.)
I think I need the 4PDT if I want the indicator LEDs and to short the unused effect to ground...?
Thanks.
Processaurus
Unless the input impedance is really low on one of the circuits (fuzz face or similar, rangemaster, wah wah, etc.) you can easily feed the input of both effects at the same time, and then use a DPDT to switch outputs and LEDs.  Or buffer and feed the two from the buffer output.
moro
Quote from: Processaurus on August 10, 2007, 01:25:19 AM
Won't I get bleed through of the "off" effect if I do it that way though? I'd feel safer shorting the unused input to ground.
GibsonGM
No, if you switch the output you won't get bleed thru.  The worst that could happen would be some 'tone suck', if the impedance of the 'off' one is too low.  Unless one is a FF or wah, you shouldn't hear any audible problems.
moro
Ok, thanks. But if I had a 4pdt lying around, would my wiring be correct?
Pushtone
Quote from: GibsonGM on August 10, 2007, 06:15:48 PM
I get bleed that way.
I put a DF Sparkle Boost and a Dist + in one box with both circuits fed directly from the input jack.
The circuit outputs go to 1/2 of a DPDT switch so the other pole can be used for two LEDs.
I can hear the Dist+ in the background when the SB is active.
I've been meaning to replace the switch with a 3PDT to solve the problem but I haven't thought about how I would wire it to short the un-used circuit.
Dave
Pushtone
Quote from: moro on August 10, 2007, 01:03:53 AM
Thanks.
That looks good to me.
What about using a 3PDT switch and taking the circuit outputs directly to the output jack?
I think I'll use it to fix my pedal. So thanks for the idea!  :icon_smile:
moro
Quote from: Pushtone on August 10, 2007, 06:48:43 PM
You mean have both the outputs connected all the time?
moro
Thanks. I thought about doing it that way initially, but for this particular pedal (Ross + Orange Squeezer), I felt like it'd be more usable to have a toggle between the two effects, then a master on / bypass.
Though I could be convinced. Would I ever want two compressors on at the same time?
Pushtone
#10
Quote from: moro on August 10, 2007, 10:00:54 PM
Yes. Both outputs from the circuit boards connected to the output jack.
Inputs are switched with the un-used circuit's input shorted to ground.
How about that?
Sure it can be done with two footswitches but the point of this thread, I thought, was to do it with one footswitch.
Something I tend to do myself but not without bleed. I really must get back to my two circuit/one switch pedal and figure this out.
