Old vs New: Do different types of caps and resistors sound different?
Started by Baktown, August 11, 2007, 08:02:09 PM
Baktown
All,
I know this is a very subjective question, so I apologize in advance for asking a "newbie" question.
Do old capacitors and resistors have a better sound for effects?  Also, do different types of caps and other components make an appreciable difference in the sound of the finished product?  Are expensive components any better than cheap stuff?
Thanks in advance!
Axl Bundy
petemoore
All,
  Sure, if the oldness sounds better to you, I prefer newest in caps because they have a shelf life and life expectancy.
  Some say old some say new...
  If you need a tight tolerance, I would use new. If you don't want to not be able to figure out which cap is a leaking or shorted without a lot of trouble use new. If drifty caps with loose tolerance is preferred, possibly extremely slight distortion old brownies would be good, IIRC they were used in some old phasers, reported to impart old mojo.
  Resistors tend to be 'resistive', but can be fried toasty, like the ones at the tube socket, generally they work just fine, in certain applications you may want to use fancy resistors, they might exhibit lower thermal noise, like huge resistors at an input [because at the input the noise might get amplified]...I never tried, all the other noise issues seemed much more...noisy, I don't think 'regular' resistors are the least bit 'noisy', probably I could tell some difference in say a compressor, cranked.
  What's 'appreciable'...lol...I'm not the one who'd know other than once in a while [rolloff cap for Q2Ff I use a brownie, I think it was JD reported a slight 'zizzing', same thing I noticed disappeared when using a metal film there.
  What;s better;? ..
  I tend to stay away from brownie caps, might use a small film cap across a big electrolytic [electro's don't really handly HF's as good as films], once in a while use a metal film or not if specified...or looks like a 'good' place for one.
brett
Hi
in my opinion, Pete hit on an important point:
QuoteIf you need a tight tolerance, I would use new.
Especially for filters and feedback networks, it can sometimes be important to be near the specified value.  The tolerance range of some modern caps (e.g. ceramics) can be enough to warrant trying a few different components.  e.g. the 470pF feedback caps in the Big Muff Pi.
Another advantage is the ready availability of smaller packages.  e.g. MKT caps are not only self-healing, have 5% tolerance, low distortion, and fixed pin spacing (5.1 mm), they are tiny, too.
There are one or two rare exceptions to the modern is better rule.  e.g. RG Keen explains the use of CC resistors in tube amps at geofex.com.  Also, things like resistor and transistor noise might, in some circumstances be considered good rather than bad if the exact sound of an old circuit or amp is desired.
Brett Robinson
Paul Perry (Frostwave)
My own 2c:
1. No carbon comp, unless you want noise.
2. No recycling old electros. Save 5 cents & risk a ton of trouble? Not even a cheapskate like me should do that.
3. No 'bypass' type ceramics in the audio path.
'Byass' ceramics are the .1uF and similar the are 'remarkably tiny for their value'. First, the tolerances for these are all over the shop. Secondly, they are one of the very few components that are demonstrably capable of distortion, to say nothing of being able to couple vibration into the circuit!
I'm not going to buy into subtle effects - but the 3 points above can make a difference noticeable to even a cloth-eared old git like me :icon_mad:
grolschie
Pedal love
This is cool. You're from Baketown? I used to run classicfuzz.com out of Bakersfield. Hit me up and I'll show you some older vintage 60's capacitors. ttak@classicfuzz.com
jonathan perez
Quote from: Baktown on August 11, 2007, 08:02:09 PM
no.
yes. but the question is too vague for me to narrow it down.
no.
http://www.diystompboxes.com/wiki/index.php?title=DIY_FAQ
no longer the battle of midway...(i left that band)...
i hate signatures with gear lists/crap for sale....
i am a wah pervert...ask away...
petemoore
  Some rules have exceptions.
  Some statements are based on opinion.
  If you buy expensive parts it's good for the expensive parts producer/distributor.
  I like using all parts that are good, brownie caps might be ok..so I tend toward not using them at all.
  I used to screw around with used electro's but quit, finding 'noise culprits' is much easier when reliable parts are used.
  I didn't compare low noise resistors to regular ones in J. Davissons Blackfire [not even on the input stage], I think it'd be an interesting study in resistor noise, being super high gain and having large value base bias resistors.
Baktown
Being new to this, I will of course have some "newbie" questions...
What are "brownies"?  Is this a type of cap, a color, or a brand?
Also, I recently bought an old Conn organ at a yard sale, and I scavenged about 300 old (huge) caps from it including some old blue molded plastic types that look like suppositories.  Are these of any use?  I have heard that these blue caps were used in old Fender amps.
Lastly, where can I buy (online) precision parts?  Cost is not a concern, I would rather get the right stuff now.
Axl Bundy
Gus
google
look for
Jung and Marsh
Steve bench
Some of the cap companies have nice PDFs
Look at the sencore site for the LC meter PDF
Things like voltage difference across the plates causing  dielectric stress and the time it takes to "relax" it something you might hear
Caps often don't cost a lot so try different ones.
jonathan perez
Quote from: Baktown on August 12, 2007, 11:30:04 AM
Axl Bundy
smallbearelec.com
mouser.com
digikey.com
oskar
I don't know about the capacitance but they are notorious for their short lifespan.
Try some plastic coating!    ::)
Baktown
Do they have the special green ingredient?  If so, I imagine they DO have a short life span!
Axl Bundy
Baktown
So old electrolytic polarized caps have a shelf life, what about non polarized caps of smaller values?
Axl Bundy
Toney
Hey Baktown...what kind of transistors did you find in that thing?
Potential for some Ge mining..depending on the model
petemoore
  "Old"..."Huge"...
  I noticed only a couple bad non-electro type caps, and I've done Lots of salvaging, sorting for boards which look clean/non burnt or heated.
  "Huge' has obvious disadvantages, when you populate the board, and the leads are too thick for the holes.
  I prefer new caps, they're easier to work with anyway, and offer assurances salvaged parts cant, my salvaged components tend to find socketted positions to be placed/tested in.
  nothing better than starting with a new, polarized electrolytic, carefull placed for polarity, never reverse polarized.
mojotron
Axl - great questions...
Sometimes one gets started with DIY effects to save money other times people want to create effects 'exactly' like the one's made in the '60's and '70's (among 100's of other reasons people get into DIY electronics...) - both objectives are attainable easily - once one has made 5 to 10 projects; of which one will struggle through the first 2 and only 1/2 of them will work right; but, once one gets 5 to 10 projects under their belt (which may take 6 months) one will discover that the quality and variety of effects that they can build is only limited by imagination, time, patience and sometimes money.
Everyone has an opinion on this, and everyone that has responded to this is correct, but it really depends on your objective and what the component is being used for. For example, if your objective is to make a really good overdrive and you only want to put $20 and a couple of days effort into it - I have built some great overdrive pedals from scavenged parts out of old radios; then the answer to your questions is "not really": But, if your objective is to build a fuzz that sounds exactly like what you hear on Jimi's first album - then you will need to do some research, spend more time/money and do things very carefully; then the answer to your questions is "absolutely".
Keep in mind that all of the people here are on a continuum from artist-hacks to engineer-scientists (most being somewhere in between) and have developed, or are developing, a sense of their own need for component tolerances. For instance one person may use old electrolytic caps because 'heck, if it fails in a cool way - I'm all over that!!'. And other people are at the opposite end of the continuum and think that life is too short for open-ended experiments and they carefully order and measure things to get it exactly right the first time. You may get 100 opinions - none of which may be valid for your ears in the end - I think you have to try both approaches to find out what you like and what you think "sounds different"...
I don't have an answer for you, but my opinion on all 3 questions is: yes. :icon_biggrin:
Baktown
Toney,
The Conn organ was loaded with tubes, not a transistor to be found!  Nearly all the tubes are branded Conn, and most are 12AU7's.
If anyone needs any of these, let me know, and I'll send you some (free, of course!).
Axl Bundy
Krinor
Wow. Maybe some tube sockets ? I'll pay you for putting some of them in the mail. PM me if you care to unscrew those sockets.
By the way: Very nice post up there Mojotron.
