Echo Base - a new PT2399 delay
Started by slacker, August 27, 2007, 04:33:19 PM
matej_mlody
I tried prepare this PDF but I can't check appropriate size. I don't have printer in home. Can someone print this PDF and check it with several elements? I  print this image to pdf file, I used to bullzip PDF printer and next  Foxit PDF editor to rotate image. Sorry my english is not really good :) this link to pdf http://www.speedyshare.com/files/25858037/echobase_VER1.pdf
Quote from: Barcode80 on December 22, 2010, 02:37:19 PM
Quote from: deadastronaut on December 22, 2010, 12:40:30 PM
this brings me to the question...
why do we always have to resize?....surely this breaks up/squares/pixelates the image, ???
or is it down to the author...hmmmmm.....you would think it was ready to print on a pdf eh?.. ::)
perhaps you are looking the gift horse in the mouth a bit?   :icon_smile:
yeah, perhaps.. :icon_wink:
i just thought the original author would have it ready to print, if they were going to the effort of putting it in a pdf..just seems like it would make sense
rather than resizing every time... :P
Barcode80
Here, I've made a ready to print pdf from anonymousfacelesscoward's layout:
http://www.aronnelson.com/gallery/main.php/v/barcode80/echobase.pdf.html
just hit "download document"
matej_mlody
Barcode80  Thank You! I think that very much people will be grateful for you. Greetings!
roseblood11
Why do you post the old version again?
The buffers in that version produce way too much hiss. (That´s why I never used my first version Echo Base!)
There are better layouts from Taylor and Dimebugg that include the improved buffers that slacker posted a while ago...
matej_mlody
#925
So... Could you give here 100% correct the best of project echo base? From Taylor and Dimebugg latest final version.
Edit:
I looking for this layout from Taylor http://www.aronnelson.com/gallery/main.php/v/Taylor/ but I don't see PCB layout, in pdf documents is only parts of list but not PCB layout. Hm...
El Heisenberg
Crap, I just got done building a PT-80 that you could switch in the delay block for the SHecho. I thought I was all sitting high but dammit, now I gotta build this. Got chorus and vibe?? Aw man.
"Your meth is good, Jesse. As good as mine."
Barcode80
Quote from: matej_mlody on December 25, 2010, 07:13:04 PM
Edit:
taylor's layout is for his prefabbed board which is multi-layered and can't really be etched by hand. If you want to use that one, you will have to buy a board from Taylor.
for that pdf i posted, i just picked the first one, forgot that it had been updated for the buffering. I'll correct and re-post in a bit.
roseblood11
Quote from: Barcode80 on December 25, 2010, 10:07:37 PM
...that´s a good choice, I think. His board looks very well-made and it´s quite small.
If you want to etch a board yourself, use Dimebuggs version (posted a few sides back)
btw: Does Dimebuggs version fit into a Hammond-B enclosure? If I ever built the Echo Base again, I would really like to make it that small.
tuckster
I made a list of all the mods I found in this thread, correct me if I missed one. It's hard to always search all the pages for a specific mod.
double delay time http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg560977#msg560977
double delay time schematic http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/album170/echobasemod.png.html?g2_imageViewsIndex=1
hold (infinite) delay http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg689765#msg689765
tempo indicator http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg604091#msg604091
blend/mix pot (remove vol. pot) http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg599999#msg599999
envelope detector http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg586937#msg586937
wave shape http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg518244#msg518244
modulation kill switch http://www.diystompboxes.com/smfforum/index.php?topic=81668.msg676920#msg676920
wiring http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg571675#msg571675
vero http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/echobasefinal.jpg.html
anonymousfacelesscoward pdf http://chawk.files.wordpress.com/2008/02/echo_base_pcb.pdf
Is the tap tempo mod really that easy to build? http://www.diystompboxes.com/smfforum/index.php?topic=60662.msg628311#msg628311
I know there is another thread http://www.diystompboxes.com/smfforum/index.php?topic=81668.0 but I'm really tired now I'm going to read it tomorrow :D
Taylor
Quote from: tuckster on December 27, 2010, 02:29:14 PM
The PTAP is no longer available. The only thing right now for tap tempo PT2399 is that Taptation available in Aron's store at the top of the forum. But it also hasn't been available for a while. I think Aron will have them at some point.
Taylor
Ah, cool! If I ever get the time to begin my modular, I have 4 EB PCBs built up for it with pots wired that way.
DimebuGG
Quote from: roseblood11 on December 26, 2010, 08:41:03 AM
I housed mine in a 125-B enclosure with a lot more spaces left. Bet it would fit in a 1590B types.
mr_deadmaxxx
hey slacker..
how do you turn ON this circuit?
did you connect the 9V to the input jack so it would turn ON only when an input jack is inserted?
is the 9V still supplying the circuit even if it is bypassed?
You can wire it up so the power is only on when the input jack is inserted, just copy one of the wiring diagrams at General Guitar Gadgets or whatever. I never bother doing that though because I only ever use a power supply and that is only really useful for batteries.
Like all pedals, the power is supplied all the time whether it is bypassed or not.
cctsim
What is the best place to buy the PT2399 chip in UK ?
I found it is available here:
http://www.doctortweek.co.uk/
Is this a good supplier ?
Thanks in advance for any help.
I've never used him but other people here seem to like doctortweek.
cctsim
Many thanks.
One more thing, Will the strip-board layout fit in a Hammond 1590B (119x94x30) enclosure ?
If not what is the best enclosure dimensions ?
