PLEASE review my new passive A/B layout with isolated grounds
Started by darron, August 31, 2007, 09:21:38 PM
darron
hi there. i wanted to make an AB box for switching amps and to eliminate ground loops. i think the design below should work, unless someone can think of a major floor in it. it uses just a 3pdt switch and should:
1) switch the signal from through to A or B
2) switch the grounding from through to A or B
3) for the unused channel, take its own isolated ground and connect it to its tip to mute the unused channel.
4) eliminate ground loops
5) switch LEDs
the layout took me about 15 mins and i hope that it's clean enough.
has this even been done before??? is this something new that i've designed? i hope so :)
thanks heaps for all of your feedback (no pun) guys :D
theblueark
Yep that's about how I've always wired my pedals. I prefer to send all the grounds to one of the jacks instead of all 3 of them though (star grounding). And I don't wire the LED ground to the jacks (helps prevent LED pops).
darron
Quote from: theblueark on August 31, 2007, 11:05:02 PM
thanks for your reassurance theblueark (: i was just hoping that there wouldn't be any hum through capacitance or something. now the hunt is on for a decent isolated audio jack (:
darron
Quote from: CGDARK on September 01, 2007, 06:41:19 AM
Quote from: darron on September 01, 2007, 05:31:13 AM
... now the hunt is on for a decent isolated audio jack (:
http://diystompboxes.com/zencart/index.php?main_page=product_info&cPath=3&products_id=11
http://www.effectsconnection.com/oscommerce/product_info.php?cPath=2&products_id=43
CG ;D
my local shop sells these:
http://www.altronics.com.au/index.asp?area=item&id=P0071
i like to buy jacks based on how cool they look on the outside :P
i love the switchcraft ones because they don't stick out far past the aluminium enclosure and they have that massive nut.
what does CG stand for?
CGDARK
Quote from: darron on September 01, 2007, 10:55:05 PM
CG ;D
They are the initials of my real name in short version, because in spanish we commonly use two names and our two last names :o:
César García
CG ;D
darron
oh of course. i thought it was an internet acronym like "lol" that i didn't know...  feel a bit stupid :P
DT :D
