A failed driver. Could it be used as a fuzz?
Started by Pedal love, September 03, 2007, 10:37:38 AM
Pedal love
I built a driver circuit for an octavia type circuit I was designing and I was wondering what you dudes thought of the sound. It doesn't sound right as a driver, but alone I think it sounds a lot better as a fuzz. I have a very short clip as I only am doing wave now. Just let me know what you think. I'll post more sound later, if asked. Thank you.
http://www.classicfuzz.com/bdrv2.wav
foxfire
well like you said it's a short clip but, it sounds good to me.
Pedal love
I wish I could add longer clips. I just can't get mp3 going.
jrc4558
Pedal love
Thanks for all the responses. There are some very cool people here. :icon_biggrin:
newfish
Sounds fine to me.
Fancy sharing your schematic?
:icon_razz:
Happiness is a warm etchant bath.
Pedal love
I tried it doesn't upload. I could send you a schematic through your pm if its ok....anybody else too. :icon_smile:
Nalo1022
If you coudl send me the schematic as well i would really apprecaite it. Ive been lookin for that sound latly
  I don't know what it is with that Tycho. I built and messed around with a couple of them [Neg and Pos versions].
  A whole lot of diddling with the Tycho and various other circuits, and the Green Ringer w alot of help gets a more usable response.
  Still the Tycho with the Tranny is quite cool, has lots of potential and can' work well, only when on a good day when everything esle is cooperating and set carefully.
  I think the driver circuit if replaced with something may get more mileage from the Iron/diode affair at the output.
  Not that I'm in the mood to figure it out...
  something like start with a clipper of the FF or Diiode to ground or double clipper, make the  symmetry/assymetry tunable [so the phase splitter can match the other schtuff and diodes to the symmetry of the waveform], shaping frequency response and output level to feed the divider circuit [transformer and diodes] what it likes best [perhaps even some type of simple pre or post fuzz compression]..then put something on the output, it always seemed to raw without some type of compression [even another OD or distorter] on the output.
  Anyway, seemed like there was some mileage in there that hadn't been paved yet..some suggestions for anyone desiring a different octave with a coil in it approach.
  Did you try the octave effect with a 12v circuit [observe the component voltage ratings], I think the fuzz section was slamming the diodes at a sharper/less variable? angle because of a taller wave or something...seemed a bit more stable and less dynamic of wierdness, sustained a little better IMCase [...IIRC it's been a while], didn't respond well to 18v.
Pedal love
Pete, you made an excellent point about voltage. :icon_smile:
Pedal love
Quote from: petemoore on September 04, 2007, 09:48:35 PM
I tried 18 volts but not 12 volts. It responded well at that voltage. I when I beef up the current it seems to sound better for my purposes. Altering voltage makes it more or less splatty but doesn't seem to change the sound character much.
Pedal love
People weren't hearing this sound file as I expanded to two topics. I like this one the best. Thanks today. Terence
