Damn Ross Phasers...Why no voltage reading?
Started by modsquad, September 03, 2007, 01:20:15 PM
modsquad
I just built my 4th Ross Phaser from the Tonepad layout.   Very simple but weird voltage problem.   I am getting no voltage reading at the point the battery connects to the board.   I unsoldered the battery terminal wires and tested the voltage and get 8v.   I soldered the negative lead to the sleave of the input jack and positive to the + of the board.   When I do that I get no voltage reading at that point.   Anybody have any ideas.   I would think no matter what was messed up in the circuit of the board you would still get a voltage reading at the boards input.
"Chuck Norris sleeps with a night light, not because he is afraid of the dark but because the dark is afraid of him"
1) It CAN happen that the connecting wire is held in place by the shrink-wrap around the battery clip, even though the wire is fractured inside.  Not common, but not impossible.
2) If I had a nickel for every time I thought I had soldered the negative/black lead to the "right lug" on a jack, I could probably buy my pedals from a store.
3) Sometimes the female side of the battery snap, or on the battery itself, can be splayed out a bit, such that the male end appears to insert but actually makes no consistent contact or even contact at all.  Sometimes a little pinch with the pliers to crimp the "petals" of the female connector inward a bit can solve that.
modsquad
Upon further review...When there is nothing plugged into the input jack I get 8v reading on the board, which is good.   When I plug into the input there is not voltage reading.  I am assuming that means I have a grounding issue.   Does that mean that somewhere I have positve voltage leaking into my grounding plane?  I just finished checking to see that all my ground wires are soldered where they should be and they are.
I have built about 15 pedals now and every darn one seems to have some new issue that I have to troubleshoot.   I think I've had enough learning experiences.
