AMZ mini booster
Started by Nuts, September 03, 2007, 05:19:46 PM
Nuts
Hi,
I'am about to build that booster form this layout :
C4 and C3 are Electrolytes
How can I know which direction to put them ?
Thanks,
Nuts.
spudulike
markm
Nuts
what does square pad mean ?
markm
Quote from: Nuts on September 03, 2007, 05:42:55 PM
It's the (+) side of the Electro Cap.  :)
ehofherr
  As shown in the layout you reference......
  For C3, the square pad is on the top, or 12 o'clock position.
  C4, the pad is on the right, or the 3 o'clock position.
Need help with woodworking?  Just ask.
Dror3332
Quote from: ehofherr on September 03, 2007, 06:12:16 PM
Are you sure about C4??? It looks logical that the + going to the left side
ehofherr
Quote from: Dror3332 on September 03, 2007, 06:41:23 PM
  Just take a look, the square pad is on the right.  You can also tell the shading of C4 if you look carefully enough.
amz-fx
The + side of C4 goes to the junction with C5, which is to the right.
regards, Jack
Nuts
Thanks everybody
So if I decide to go with that layout http://www.aronnelson.com/gallery/v/MarkMs-Gallery/album15/album76/AMZ_MiniBooster_LAYOUT_001.gif.html?g2_imageViewsIndex=1
it would be, for C3 the square pad is on the left, or 9 o'clock position
Right ?
markm
VinSent
I think the square bads are, in both cases (c3 and c4), on the right side - 3 o´clock..  :icon_eek:
Nuts
Quote from: VinSent on September 04, 2007, 08:17:47 AM
yeah, that's the way.
I just got confused, and I guess I was confusing markm...
Dror3332
After looking inside the schema it looks like
C3 it's obvious that (-) to the ground
C4 is 3.3uf NP
Dror
nooneknows
for guitar use I've found an interesting value od .68uF for C3, this eliminate the problem with the polarity too.
it reduces a bit the bass side, the sound is still full but the overdrive of the following stage is much more pleasant to my ears.
A matter of taste, of course
markm
Quote from: Nuts on September 04, 2007, 03:54:07 PM
That's not hard to do sometimes!  :icon_lol:
