Bipolar PSU - which transformer?
Started by axg20202, September 05, 2007, 02:02:51 PM
axg20202
I'm planning on building a bipolar PSU using the instructions and layout on GGG. The trouble is, it's not totally clear what kind of transformer to use. I'm guessing this is because many are suitable. I need +/- 15V, so I know it needs a secondary that is at least 18V (AC not DC, right?). But which kind is suitable? If a transformer has two secondaries of 9V each, will this work if I connect them together or do I need a xformer with at least one 18V secondary?
I am in the UK (220-240v primary), so if anyone has a good source for a model that is suitable I'd really appreciate it.
axg20202
#2
Yep, I already read that RG. The GGG layout uses what you describe as the more crude method to generate raw DC to supply regulators for a bipolar supply. What I can't decide is whether to buy a 9V + 9V dual secondary transformer and sum their outputs (is this simply done by connecting the two 9V terminals and then going straight into the rectifier diodes?) or get a transformer with a single 18V secondary.
I would have thought that the 9V + 9V option would be cheaper and come in a smaller package for a given total VA rating versus a larger, more expensive package for the same VA rating with the single 18V secondary. Any ideas on the ideal minimum spec for what I want to achieve as I really want to resist doi ng my usual overspecing job - I need the works to be as small as possible while being capable of turning out a good 300 mA or more if possible?
Cheers.
axg20202
...also....the build instructions recommend using heatsinks but gives no guidance on this whatsoever. Assuming I use T0-220 package 7815 and 7915 regulators, just how substantial do these heatsinks have to be? Are we talking the little skinny ones with tiny fins with a base plate the same size as the tab on the regulator (available as clip on types from some suppliers)...
http://www.maplin.co.uk/module.aspx?ModuleNo=2583&doy=search
.......or do I need some that are great big lumps?
the_random_hero
Quote from: axg20202 on September 05, 2007, 05:48:27 PM
It all depends on what sort of current you're drawing out of the regulators. The larger the current draw, the larger the heatsink. I'm just using a small screw-on aluminium type with some heat paste and it does get fairly warm when I'm drawing around 500mA, but not ridiculously hot. If I ever wanted to draw more current, I'd just go up to a slightly larger heatsink.
Completed Projects - Modded DS1, The Stiffy, Toaster Ruby, Octobooster Mk. II, Pedal Power Supply
axg20202
Thanks. I'll just have to try some options. The fact that the heat sink gets warm/hot shows that it's working I suppose, so as long as they aren't too hot to touch, then all should be well.
Would still appreciate some tips on the transformer though.....anyone?
