Wanted: PCB layout containing pads for Norlin 3P4T rotary switch
Started by powerplayj, September 05, 2007, 03:09:37 PM
powerplayj
I am working on a complex switching mechanism for a true bypass loop which involves a rotary switch identical to the one Small Bear carries.  It looks as if a PCB layout may prove to be neater than wiring all the lugs together.  Can anyone direct me to a PCB layout that has the correct spacing for mounting the switch I mentioned.  I plan to use MS Paint, to adapt an existing layout to one that meets my needs.
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
theehman
I just did one for ExpressPCB.  I can export it as a BMP if you want to try it.  I haven't verified it yet as my boards haven't arrived yet.
Ron Neely II
fx schematics and repairs
markusw
The String Ringer layout also has two of them. It's in the pdf project file.
Regards,
Markus
powerplayj
Thanks to both of you.  I grabbed the String Ringer PDF and moved it into a bmp.  I'm glad I'm not building the String Ringer!  I've built the ADA Flanger, Neovibe and PT-80 but this one might take the cake for difficulty.
next build(s): ???
theehman
Ron Neely II
