Tremolo Expression Pedal question
Started by guitron, September 06, 2007, 12:02:47 AM
guitron
Hello,
    I'm attempting to build the Tremulous Bear offered by Small Bear Electronics.  This is my very first try at building a stomp box.  I'm wondering if I can do a mod so that I can connect it to an expression pedal to control the tremolo rate.  Is this possible??  Would I be able to use a standard ernie ball volume pedal??  If so, would anyone be kind enough to explain how to do it?  Any help would be greatly appreciated.
Thanks,
Ron
jlullo
http://www.geofex.com/Article_Folders/xprnped.htm
check out the link... you can use a broken wah/volume pedal, or smallbear sells empty ones for around $40
guitron
wow, you guys are fast!  Thank you very much.  This seems like it will work.
Ron
jlullo
