Colorsound Overdriver transistors?
Started by burningwater, September 09, 2007, 01:58:01 AM
burningwater
I want to build one of these but cant find the transistors.
Can anyone suggest a good current production mouser replacement?
I did a search and all I found were BC109s which I think are also vintage?
I believe the overdriver takes NPN silicon and if anything like the tonebender I build they should be low hfe?
Also if you could suggest optimal values for Q1, Q2, Q3.
$uperpuma
futurlec has bc109s if you dont mind waiting a while
smallbearelec
Build with sockets, and try these from my Stock List:
SKU 2023 BC109 Work-alike
http://www.smallbearelec.com/Detail.bok?no=272
I also just got some NOS, UK-manufacture, military version BC109. Will be posting those this week,  price $1.00 each.
Regards
SD
burningwater
Thanks SD, whats the difference between all the numbers, 108, 108B, 108C, 109, 109C
Are they different hfe values or different applications?
yeeshkul
B and C it are a hfe classifiers as far as i know, where C is the top.
smallbearelec
They are different gain ranges, and yes, they do overlap. BC108 is the lowest of all. The BC108B and C are higher-gain buckets of the type. BC109 is higher gain than the 108, and the B and C versions are the highest-gain of all of these.
burningwater
