What is the right Ge NPN for FD2?
Started by lynessmy, September 10, 2007, 06:17:02 AM
lynessmy
I wish to playing around TS8 PCB i have now to FD2 spec.
What is the Ge NPN is should use as OUTPUT transistor?
I had got 2SC75 and 2SD23 on hand but not sure is a good fit.
MartyMart
I'm not sure why you want a Ge there ?
I'd just go with a good 5088/89 or an MPSA18 for output, do you want some added
noise ??
MM.
lynessmy
My aim is to reduce the mid of the pedal and get it less muddy when doing chord work.
I get the Ge Output transistor idea from FD2. According to Steve Cerutti schem, FD2 has Ge NPN.
I had actually tried 2SC75 and 2SD23 on the board i presently have.
I agreed, Ge NPN is not as quite as 2n5088 but it sound clearer & less muddy.
Though, C75 is not a good subsitute. The noise is higher.
But i found D23 is quite ok with manageable noise. I think i will be much lesser when i box it up.
It improved the sonic character for chord work.
The other improvement i'm still looking for is reduce the mid of the pedal. Any idea to do this?
I would like to tried to further reduce input cap value and the 51pF of feedback loop Cap. Will this help?
jlullo
i don't believe that the fulldrive 2 has any sort of Ge device in it.  you're not going to be able to just substitute a Ge transistor for a silicone without some tweaking, and most likely a trimmer.
as for reducing the mid hump, check this out-
http://www.muzique.com/lab/fatt.htm
