Can't find info on this part # anywhere :(
Started by snoof, September 12, 2007, 01:12:32 PM
snoof
8  pin dip, marked JRC4028B.  No luck on Google.  it appears to be a reg 8pin opamp, but I can't be sure.  anyone know anything about this??
Dagreb
snoof
when I search for 4028, 4028B I get references to a "1 of 10  decoder" 16 pin.
Paul Perry (Frostwave)
I found by googling that the CabTone cabinet simulator contains one of those chips, so if anyoen is familiar with that circuit..
but I suspect it is a decoder as Dagreb says, because many JRC chips are just other manufacturer's standard chips with the NJR prefix added (not always.. but the B for 'bufferd' is a strong CMOS hint!)
snoof
My hunch is that it's a opamp.  There is 3 of them in the crkt (Voodoo Microvibe) and there is no other IC's(cept for the wierdo one that has to do with the switching).
Snoof, which pin does the + voltage go to? If it is pin 14 it is prob a logic chip, if pin 11 it is prob an op amp :icon_wink:
goodrevdoc
I would say it is a dual op amp. This is based on a crazy guess that i came up with just now. Checked out mouser digikey and the nte xref pages to no avail. A CMOS 4028 is a 16 pin device, but snoof said that this is an 8 pin dip. Check pins 4 & 8 for power and ground connections. If those are there, trace out pins 2 & 3 and 5 & 6.  if those seem like inputs, then look at pins 1 & 7. Those would be outputs on a standard dual OA.
-justin
snoof
yes it's def 8pn dip, not 14.  Power does go to p8, and grnd p4.  It's odd that that number doesn't show up anywhere though, maybe it's a custom OEM sorta thang.
Sorry for muddying the water. Clear missed the very first word in the post - EIGHT pin :icon_redface:
Um, this might be an opportunity to say "welcome to the world of house numbers". :icon_eek:
There is a distinct possibility that this number is unique to one manufacturer.  It happens.  Just TRY and find an EH-1048 in any supplier's catalog anywhere.
Dagreb
Quote from: Mark Hammer on September 14, 2007, 12:58:09 PM
This sort of thing happens in other manufacturing industries as well. Just to confuse the reverse engineer?? :icon_wink:
