transformer for spring reverb?
Started by caress, September 24, 2007, 09:41:06 PM
caress
i'm building this reverb design by forrest cook:
http://www.solorb.com/elect/musiccirc/reverb2/index.html
i'm all set but curious about the transformer...  i found this one on mouser - 42TU400, which is a 500CT - 8CT.  on the schem, there is no connection for the center taps...  can anyone advise me on how to wire this or if i even got the right transformer?  also, the P side is the 500ohm side, right?   :icon_redface:
dirk
The Mouser trafo you selected has a power rating of 0,46 Watt.
The trafo in the schematic needs to be 10 Watt.
d95err
I don't see the point of using a transformer with a solid state reverb driver. A small SS poweramp like an LM386 chip should be able to drive an 8 ohm reverb tank directly.
stobiepole
You should be able to work it out from this layout image:
http://gaussmarkov.net/layouts/springrev/springrev-perf.png
The whole project PCB is here:
http://gaussmarkov.net/wordpress/circuits/spring-reverb/
I used a standard 42TM018 Mouser type transformer, from memory.
Chris
Arfman
Quote from: caress on September 24, 2007, 09:41:06 PM
You should be fine, just don't use the centertaps.
Yes, the primary is the 500ohm side.
Quote from: dirk on September 25, 2007, 12:04:00 AM
I think the Mouser one will be fine, and the seeming need for a 10W transformer is really more one of a unit that Forrest Cook knew would have the needed primary and secondary impedances.  The recommendation likely has nothing to do with required power-handling capabilities.
Quote from: d95err on September 25, 2007, 05:41:14 AM
True, and that's why the "other" circuit Cook shows uses one. http://www.solorb.com/elect/musiccirc/reverb/reverb.gif
On the other hand, his use of the term "obsolete" suggests that the second one has some sort of sonic advantage, or perhaps simply a current-consumption advantage.
caress
thanks for clearing up some of my questions...  great replies
