Boss OD-3 BD-2 Question - Help (R.G.?)
Started by Rayman, September 30, 2007, 08:20:36 PM
Rayman
Can anyone explain how the circuit involving the q11 (pnp), q13 (jfet), and q14 (jfet) transistors on the Boss od-3 schematic works?  This same type of circuit is used in the Boss BD-2, but I can't find anything in this forum or on the web that explains this configuration.
Do you have a link to the schematic you can post, so we're talking about the same thing?
OK. It's a discrete opamp.
Q13 and Q14 form a simple differential amplifier, biased by R50. Q11 is a voltage gain stage, converting the signal from R37 into an output voltage. The output pin is the junction of R52 and Q11, the + input is the gate of Q13, and the - input is the gate of Q14.
R36 and R49 are a bias voltage divider. D10/D11 are a feedback clipping diode network, and Drive, R38, R51, and C33 perform much the same function as the clipping opamp stage in the tube screamer.
Rayman
thank you so much.  I see it now.  If I new what a discrete opamp was, I probably could have seen it.  that explains it perfect.  I need to do some searching to better understand discrete opamps.  thanks again R.G.
Rayman
