extreme mid scoop help please!!!!!!!
Started by geoffro, October 08, 2007, 01:51:25 AM
geoffro
Hi Just me again.
I am wanting to try an idea with the ac-2 pedal circuit i have made.
I would like to cut the mid out if i could, at around the 1 to 1.1khz level as i was thinking this would help me in my endeavour to use a guitar with humbuckers to sound a little closer to a single coil as the varitone control does on the gibsons.
so my question is how can i achieve this, do i need to make something like the MR EQ which has a setting on it that cuts the mids right out and leaves the lo's and high's on, or since this circiut has a mid control in it with a bandpass filter of 1khz can i just do somthing with this???
i know i am probably asking a stupid question but i have been doing a lot of reading to try and get some knowledge so as not to bother people to much, but just a little nudge in the right direction would be of great help.
thanks
geoff
aron
Weird. I was just looking at something like this.
You can use a 1.5H inductor with a resistor/cap to cut mids.
http://www.jpbourgeois.org/guitar/micos1.htm
http://www.firebottle.com/fireforum/ff.cgi?cmd=vt&fid=gt&tid=11471575992u45NOx
Varitone circuits:
http://www.blueguitar.org/new/schem/_gtr/
Check out this one -  greasebucket tone control:
http://guitarnuts2.proboards45.com/index.cgi?board=wiring&action=print&thread=1123091479
keywords: MIDRANGE TONE CONTROL
geoffro
Ok so i have just found some info
and please correct me if i am wrong but with the 10k pot i already have in the circuit for the mid control if i conect it to ground will it or wont it cut my mids?????
geoff
aron
geoffro
aron
I think you are right. If you remove R29 and connect the 10K directly to ground, it will cut more mids.
geoffro
#6
thanks aron,
one thing though do i still have the wiper of the pot going to c13
or do i do it like this
http://hammer.ampage.org/files/modded_fy-2.gif
aron
geoffro
so will this cut all the mids at 1khz or only some.
sorry for the noob questions, trying to learn a bit
thanks for the help but i appreciate it
geoff
aron
geoffro
yep just about to take the resistor out and put in a jumper and see how it goes
will let you know
cheers
geoff
geoffro
ok i did it, and there is deffinitely an improvement, although there is a noticable drop in volume, but you cant have everything hey
now i just have to stabilise everything else now so when it goes back in the box it doesn't do the old heart beat thing
one thing i have noticed is the popping when i press the dpdt switch, i have the melenium circuit hooked up but it dont seem to be working real well.
cheers
geoff
