opamp wanted for 5 volt powersupply
Started by alfafalfa, October 10, 2007, 10:03:58 AM
alfafalfa
This may a simple question for some but I haven't a clue.
Can I use  a simple TL072 opamp with a supplyvoltage of only 5 volts , or may a symetric  supply of  + and -
2.5 volt ?
If not what opamp will do the job ?
Alf
Gus
manufacture spec sheets will often give power supply voltage range.
gez
ICL7621
ESR/Farnell in the UK
Mouser in the States
Rail-to-rail output (CMOS), plus micropower.
alfafalfa
Thanks  Gez,
I think that one will do.
A friend of mine needs one to make a currentsensing device and wants to use the supply voltage of a computer.
Alf
