Building a Rams Head and Triangle Big muff.
Started by msurdin, November 11, 2007, 09:37:05 PM
msurdin
Hey Guys,
I am really wanting to build a Triangle and Rams Head Big Muff. As close as I can get to the originals.
I saw this post and see the picture to make a pcb. I dont have the tools to do this at my place or the proper area.
I was wondering if the GGG Board would work for an original triangle muff. (http://www.generalguitargadgets.com/pdf/ggg_bmp_pcb.pdf) the board is obviously different.
Is there any good layouts of the ramshead around?
This woud be a giant help guys!
Thanks a lot
Matt
frankclarke
Here are the schematics for lots of versions, if you are just talking about different component values you can use the same PCB. If there is an extra component or 2 you should still be OK, but you have a little more to think about.
http://www.pisotones.com/BigMuffPi/psst/BMP_versions.htm
I would risk it.
