Expanding the TS-9 Tone Control
Started by amz-fx, November 12, 2007, 09:55:30 PM
amz-fx
New article that I posted today....
http://www.muzique.com/lab/main.htm
Enjoy!
regards, Jack
96ecss
Great article as always.
Thanks Jack.
Dave
1) Thank you.  I have grown weary of typing out explanations of that control, and those initial two ictures saved me several thousand words. :icon_biggrin:
2) VERY clever ideas with respect to just changing the location of a few nodes.  Some nice out-of-the-box thinking on your part.  Hard to do when the circuit in question is a classic and people can't imagine it any other way.
3) It had never occurred to me until seeing it redrawn this way, how close a relative the TS tone control was of the SWTC.
4) The Maxon precursors to the TS-808 included an OD-805 (num?) that reversed the order of the tone and gain stages, such that the tone control preceded the gain/clipping stage.  Seeing these circuit suggestions, and particularly considering their more powerful tone-shaping possibilities, kind of makes you wonder whether there is still some life in the earlier version of the basic circuit, or perhaps some sort of perverse combination of pre-clip tone stage plus post-clip tone stage.  Who knows, maybe this is a solution to the mid-hump/bass-thinning problem that so many have tried to ameliorate.
beatstrat
Good stuff - thanks, Jack; your Lab Notebook continues to grow in wealth, girth - and value.
MetalGod
Interesting reading as always - I'll have to try those out.
8)
vanhansen
Great read.  I never tire of your articles, Jack.  They've helped me out more than once in my adventures.  Thanks for sharing all that you do.
Erik
Kornell
Interesting stuff. I reckon you could build a killer pedal based just on the stuff in the AMZ labs.
amz-fx
I just updated the article with a couple of other configurations, including one interesting two-band one-knob control  :icon_biggrin:
regards, Jack
YouAre
I liked the wah inductor idea! Is there any component to change to shift the frequency of the mids dip/spike? What would be the equation to achieve the desired frequency?
thanks,
murad
MartyMart
Great stuff Jack - as usual !!  :icon_wink:
Marty.
amz-fx
Quote from: YouAre on November 15, 2007, 03:56:15 AM
The info you want is now in the article.
-Jack
wampcat1
jack - great stuff - sending you a PM about something...
bw
YouAre
Quote from: amz-fx on November 15, 2007, 08:43:55 AM
-Jack
Thanks! I believe you said in one of your articles about the TS that the corner frequency of the TS mid hump is about 750hz (if it wasn't your article, I apologize). Would you say that's about right?
Also, I calculated what it would take to get about 750hz. A .9uf cap (a 1uf and .1uf cap in series works) would get about 740-750hz (depends on tolerance of cap and wah inductor!) for anyone that's interested.
amz-fx
Quote from: YouAre on November 15, 2007, 12:35:29 PM
A 1uf and 0.1uF in series will be about 0.09uF
Series capacitance = (C1*C2)/(C1+C2)  = 0.1uF/1.1uF = 0.09uF   :icon_smile:
regards, Jack
YouAre
Quote from: amz-fx on November 15, 2007, 10:28:10 PM
regards, Jack
i made a typo in there somewhere....i'll fix it later. haha sorry
YouAre
My Apologies, I knew it was a .09 uf cap, i just made a typo with .9 by mistake.
But a .09uf cap will yield the 750 hz according to that equation.
Still, is that close to the right frequency of the screamer's nasally middy character?
YouAre
Quote from: amz-fx on November 16, 2007, 06:29:57 PM
You are probably thinking about this article:
http://www.geofex.com/Article_Folders/TStech/tsxtech.htm
regards, Jack
ah yes! my apologies for mixing them up. But would you say 750hz is a good frequency to go for?
YouAre
sorry to bump an old thread but..
i tried to implement the inductor tone control with MarkM's od808 layout (the tone control layout as described in the original article was the same as on the maxon). I don't think i get as pronounced of a midrange boost or cut as i would like with the new control. I used a .09 uf cap. How pronounced should the cut/boost be?
come to think of it....i might have used the 20k G taper pot that smallbear sells. Should i use a 25k linear pot instead?
Also, is it possible to add another pot so that i have the stock tone control as well? Ideally, i'd like the tone control and the mid cut/boost knob.
regards,
murad
