Help with transformer wiring---Electric Mistress
Started by sjaltenb, November 13, 2007, 03:30:31 PM
sjaltenb
Hey...
I have a Deluxe Electris mistess, the one with the transformer in the pedal casing. So i took the board out to put in a multieffects project... so i also but the transformer away from the wall plug which is permanetely attached to the casing.
So on the wall end of the transformer theres a red white and black. The red was always head shrunk off and not used. The ground from the plug leads to an attachment to the casing. So theres a black and white wire which attach to the main power plug....Which is my live and which is my neautral?????
stephanovitch
Transfo have no polarity, it's like a resistor.
you can invert wires whithout problems if it's the primary of the transfo.
