Red Llama clone not fuzzing... plz help
Started by solarplexus, November 18, 2007, 09:13:47 PM
solarplexus
Hi there,
just built a Red Llama clone from Markm layout (the old version) and the volume pot works backwards although it is wired properly from the layout and there is no fuzz, just a volume boost.  Any idea what could cause this ??
Here's Markm Layout (sorry Mark please let me know if you want this removed) :
The only different part I used was a regular electrolytic cap for C5 instead of a tantalum.
Any ideas??
DIY Poser.
Papa_lazerous
If the volume pot is reversed swap the wires from the outer 2 lugs.......... ;)
solarplexus
Thanks... did that... same story.  If I push the IC with a booster before the pedal there is some fuzz there but not alot... ?   ???
DIY Poser.
frankclarke
Does the Gain pot do anything? More data required.
solarplexus
the gain pot does very little but add only volume.
DIY Poser.
dschwartz
check values for R1 and r6. its a voltage divider and can be lowering the signal too much.. try lowering R1 for more gain..
check the gain pot also..
Tubes are overrated!!
http://www.simplifieramp.com
frankclarke
Quote from: solarplexus on November 18, 2007, 09:58:47 PM
No, it can't be the same story if you wired it correctly. It would be worth checking your resistor values, solder joints etc. You can build the circuit without a board in about 30 mins, it would be easier to rebuild than to debug.
frankclarke
The pins for the buffers should be around half the supply voltage if that helps any.
