Good Compressor for Bass
Started by ruispeeds, November 21, 2007, 10:24:23 PM
ruispeeds
Hi there,
does anyone know a good compressor pedal to build for bass guitar?
If you have a schematic/pcb that would be great.
Many thanks
Tiruk
Hey man,
I recommend you the Orange squeezer w/ bass mods. Have the pcb/schem on tonepad.
Simple, easy to build and sounds really good.
oldrocker
I second the Orange Squeezer.  I didn't do any bass mods to it and I use it on my bass always.
Meanderthal
 OS is good (I would even go as far as to call it 'idiot proof'- it does what it does well and ya have a hard time screwing up your tone with it!), but for more versatility, the Ross/Dynacomp is the one I like. Raise the in and out decoupling caps to 1uf or higher and yer good to go with either one.
ruispeeds
Hey guys,
thanks very much for the advising, i guess i'll try to build both of them. :icon_smile:
oldrocker
If you get around to building a Zombie Chorus and a Mr.EQ they go together great with the OS on the bass.  That's what I use on my bass rig.
The OS tends to function a wee bit more like a limiter, which is what bassists tend to like.  If you go with a Dynacomp variant, go with the variable recovery mod (changing the 150k resistor to maybe 22k-27k or so), and you'll probably end up with something you like.  A stock Dynacomp/Ross is really geared more at the guitar player who wants to bend a G or B string and hold a bent note for a bit.  A bass player generally just wants a limiter to keep the average signal level steady, rather than assist in sustaining anything.
