red llama capacitor question?
Started by stratblues, November 25, 2007, 04:31:18 PM
stratblues
I am using the layout from http://gaussmarkov.net/layouts/redllama/redllama-project.pdf
C1       .068uF         gm-caps-film-box
C2       51pF           gm-caps-ceramic
C3       100pF          gm-caps-ceramic
C4       .033uF         gm-caps-film-box
C5       10uF tantalum  gm-caps-tant
C6       330uF          gm-caps-electro-pol
I figured it would be ok if I used poly-film for C1 - C4. And made C5 and C6 both electrolytic. (is that ok?). Has anyone substituted C2 and C6 because I can't find them anywhere!? I did find C6 at partsexpress.
Celadine
You can try the nearest value for C2, 47pf or 56pf.  330uf polarized caps shouldn't be too hard to find, but you can always parallel 3 x 100uf caps, it would be the same thing.  (or any values that add up to 200-300uf) Happy building!
frankclarke
It doesn't have to be 330uf, just something big. Nearest value for caps, yup.
joelap
Some notes regarding C5 that was discussed extensively in a previous thread:
I've heard Mr. Huge claims only a tantalum cap sounded right to him in that position, not sure how true that is or not.
An interesting dilemma I found with that cap is the bigger the value, the better the effect sounds when used on a guitar's bridge pickup, but the worse (muddier) it sounds on a neck pickup.  I think I settled on .068uf (big change from the stock 10uf).  Have some fun there.
- witty sig -
nbabmf
I paralleled two 100's for C2 and used a 470 for C5.
