DIY Layout Creator - Help needed with component icons.
Started by bancika, November 27, 2007, 03:15:11 PM
scaesic
having electrolytic caps would be useful because you'd need to indicate the polarity. Resistors would look better if you shaped them a bit so they baloon out at the ends and slim in the middle?
The rest is looking good. (transistors need a couple of arrows)
arma61
Hi
no way for me to contribute to the icons creation  :(. My contribution is a BIG thank to bancika and all of you working on this project. It makes my mouth water  :P looking forward to see the final release.
And it's almost Christmas, you don't say that.....
good job guys.
Ciao
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
scaesic
Quote from: scaesic on November 29, 2007, 05:30:00 PM
One more niggly thing, the op-amp needs a dot next to pin one.
dschwartz
boomer..i wanted my icons to be there.... :'(
anyway, if someone needs icons:
Tubes are overrated!!
http://www.simplifieramp.com
