I have not clue if this will work (help!)
Started by sengo, December 07, 2007, 01:12:02 PM
sengo
Hey guys,
    I had an idea for this months design challenge, but I have no idea if this will work as I'm not really that knowledgeable about electronics. I was hoping to use 1381 voltage triggers and a dual red/green LED as a Fuzz Face bias indicator. The idea being that the pedal would have a third "bias" knob, and the LED would be remain red until you biased it to around 4.5 volts, at which point it would turn green.
    There are a lot of little reasons I don't think it will work as is, but maybe someone here will know what to do so it does? The transistors I used are not the correct schematic symbol, I think I was suppose to use something that looked like an inverter, but with three leads.
I hope This will actually be useful,
Nick
Edit: on the schematic, the bottom LED is meant to be red and the top one is meant to be green.
