Tube boost + overdrive running off a 9 volt battery
Started by dano12, December 11, 2007, 07:51:24 PM
Renegadrian
Jimmy-H, your layout is so much appreciated, so thank you!!! Nice job!!! Wait for some more info (how much gainy is that fx?) and possibly some sound clips!!!
Rick, your valvy turned out great...I love that kinda finish...
Pushtone
I've been thinking a lot about the Valve Caster's two stages and where a two band EQ would work.
I applied the AMZ JFet buffer and Dual Tone control circuits and spliced them into the Valvecaster.
The Zed Caster has the buffer and tone circuit up front.
The Lab Caster has the buffer and tone in between the tube stages.
Never done this before. How do they look?
Are they both viable circuits still?
Which one would be most successful?
Dave
brett
Hi
I think it would be safest to put a buffer (JFET makes sense) at the end, before the 100k volume pot.  Otherwise, the impedance of the load might be too low for the seond valve stage.
cheers
Brett Robinson
Jimmy-H
#443
Hi there,
The Pepper Shredder has plenty of gain.
An other idea is to leave the Tonestack, and then make a input cap selector (just like the Orange amps).
Then you have a more powerfull sound.
But I found some sound samples of the Vanilla Drive and the Pepper Shredder.
The Vanilla Drive is a little milder.
(According to the designer, the Vanilla drive can be used as a clean booster to a mild overdrive)
The tubes he used are 12AU7 from Electro Harmonics.
Here is the link : http://www.tube-town.de/ttforum/index.php?topic=7797.0
Only it's in German, but what the hack, so is the design
The Layout I posted has dissapeared, strange.
But here is it again:
Ok, having built my Valvecaster I am now completely obsessed with vavle FX. I woke up this morning with the idea of an all tube multi-FX board going round my head. I think it would include:
1. a Valvecaster
2. part of The Tone God's tube tremolo
3. tube reverb (should be easy to adapt the VC to do this)
4. a tube based phaser - not sure if this one is possible???
Imagine: 4 stompswitches, half a dozen or more valves..........ooh! Any thoughts or ideas?
Renegadrian
JimmyH, I read more on that forum...Some babel translation and it's more readable!!!
The pepper sounds good!!! Gotta build this one...
ambulancevoice
Quote from: frequencycentral on April 26, 2008, 05:43:28 PM
I'm defo going to build a combo with a Valvecaster, Ruby and 12" speaker - powered from a 9v battery!!
your not going to power both of them with one 9v battery? cause that wont do very well
Renegadrian
OT
Andrew, is the guitar on your avatar one of yours? Are you left handed?
andrew_k
Quote from: Renegadrian on April 28, 2008, 06:30:36 PM
OT
Yes and yes  -- it's a Carvin Fatboy, but with a walnut neck and mahoganhy+quilted maple body. Highly recommended  ;)
Renegadrian
Krinor
Quote from: frequencycentral on April 28, 2008, 05:31:46 AM
Anything is possible. But keep in mind that a phaser incorporates 5 ic's (Small Stone). Each of them includes 11 transistors and 6 diodes. Now imagine doing what that little CA3080 does, only with tubes - times 5. A tube phaser would be fabulous though. Maybe there is another way ? :icon_wink:
Renegadrian
I just uploaded a pdf file of a tube preamp, you can find it HERE
It's a very little and easy circuit and the 6418 is so easy to find and cheap.
Didn't build it yet, but hey it's so simple...I'll report it soon, I believe...
Fender56
QuoteI just uploaded a pdf file of a tube preamp, you can find it HERE
Pentode preamp at low-voltage? COOOOOOOOOL!!!!!!!!!!!    :icon_biggrin:
Hope it will be able to recreate the famous EF86 sound! (without the microphonics... ;))
iorr
#455
Valvecaster sounds really good for me. Builded it yesterday with IC 7812 and ECC 82.
Sample here : Tele -> valvecaster -> emu 0202 soundcard -> cubase.
Karsten
Berger
here is the dual subcaster that I've breadboarded...I'll get it in an enclosure soon, I really like it
dano12
Quote from: Berger on April 29, 2008, 03:59:49 PM
Ahh....sweet glowing tubes.
Man, this thread has become a monster!
armstrom
So I take it a single 6.3V power supply board (per the schematic) is sufficient to drive both heaters? I plan to use two tubes, but in a stereo configuration as my preamp stage. I bought both the 12AU7 tubes as well as the 6111's to see if there's any serious difference in gain. The 6111's will fit much better in the enclosure I plan to use, so that's what I'll build first.
-Matt
Berger
Yup Dano this thread has taken off, its got me going crazy buying tubes, even better is that I'm starting to understand this stuff, and am having a lot of fun.
The only thin I notices is suppling enough amperage to the circuit for it to work right. I was using a 12volt 300ma radio shack wallwart and would get flubby sounds out of it. I switched to a 700ma power supply for work and it sounds amazing.
