TS9 help!!!!
Started by machineman, December 12, 2007, 11:55:55 AM
machineman
My TS9 still doesn't work after a few trouble shoots that I did (made sure that I didn't have a cold solder and made sure that I didn't have any bridges.
Anyway, I will measure the voltages and post it asap
the problems are:  There is volume but it is weak.  The gain control doesn't work...
jonathan perez
i think i have the same problem on a tube screamer i built and tossed a few months ago in the closet...will keep an eye on this thread..
on second thought, only the gain control doesnt work...
no longer the battle of midway...(i left that band)...
i hate signatures with gear lists/crap for sale....
i am a wah pervert...ask away...
machineman
im actually really pissed about this because it seems to be a small problem...somebody help us...
ethanw
I use an audio probe, basically a cap attached to cord and 1/4 jack. Instructions can be found on this site. This simple tool finds errors quickly!
Ethan
machineman
can't seem to find the audio probe instructions....please post it thank you
gaussmarkov
JFX09
Quote from: ethanw on December 12, 2007, 05:34:54 PM
Ethan
I can vouch for this wonderfull tool, made it simple to follow the signal and see where the problem was on my first build.
Happiness is a effin' hot soldering iron
machineman
thanks people!!! it's working now!!!!  Don't need an audio probe for this project...but i will make one definitely.
Fuzzy-Train
What was the problem/fix?
I was having the same problem with mine and I replaced the diodes with the same type and it works great now... must have been a cold joint.
THERE IS NO SIG.
The user formerly known as NoNothing.
Stuff I built!
http://s174.photobucket.com/albums/w106/Cpt_sergeant/?start=allRandom
Jobet
Cold joints on the diodes will not prevent the pedal from putting out sound. In fact the sound will be even stronger.
A short circuited signal path, will. :D
Fuzzy-Train
I had sound, just no distortion. It was the only area where my iron touched, and it made it distort... what else could it have been?
THERE IS NO SIG.
Stuff I built!
