Just an idea.
Started by jpm83, December 13, 2007, 08:30:09 AM
jpm83
I was thinking if it would be possible to make that kind of runoffgroove tube to FET adaptation on 7ender standalone tube spring reverb?
Janne
jpm83
jpm83
Nobody interrested on this one???
John Lyons
Not what you are asking for but here is one. http://sound.westhost.com/project34.htm
It would be possible to make a tube to FET reverb I think...
John
Basic Audio Pedals
www.basicaudio.net/
Gus
Yes one can make a fet  reverb (jfet and power mosfet)I would use a SE power mosfet drive for the transformer.
Things to think about gain vs headroom?
Drive to the coil?
What power supply voltage for the unit?
jpm83
#5
Thanks for the link. I think you could use the Reverb Input Transducer Drive Amp from that site in this project to ease things up a bit.I started to make a some kind of schemo  and here is it
jpm83
Should I continue to desing this or was my idea dead as it was born. And thanks for replies.
Krinor
Quote from: jpm83 on December 13, 2007, 12:23:49 PM
Please do. And be sure to post your results.  :icon_wink:
dano12
Quote from: Krinor on December 13, 2007, 02:26:22 PM
Yes, a clips and photoessay would be great. Thanks.
jpm83
O.K here is a schematic   Could someone check it for any obvious mistakes and tell me what do you think about it.
Janne
jpm83
My first instinct is to say don't waste your time.  There are a number of reasons why I say this.
  • The reverb circuit is not about distortion, where many of the ROG emulations are intended to achieve the unique distortion qualities of various amplifiers.
  • FET front-ends are great for when you want to be assured that you hang onto all that wonderful top end of your single-coils.  Have your heard what comes out of a reverb pan?  No top in there at all.  Why struggle to preserve it?
  • The key part of the Fender circuit and circuits like it is delivering a high enough current to the springs.  The 6K6 is an output tube, similar to a 6V6.  This is why the preliminary circuits posted here have used a 386 power-amp chip (though there are better circuits).  Once you opt for using a power-amp chip, the FET-for-a-tube strategy, so useful in the various ROG circuits, is essentially sidelined.
Though I suppose there are things like headroom and such, in the final analysis, the input signal toneshaping and the springs themselves are such huge determinants of the reverb tone, that whether you use tubes, FETs, or clothespins and masking tape is really immaterial.
My advice: pick a known working reverb circuit, drop a few extra bucks on a long 6-spring pan, and spend your time playing with the tone shaping cap values rather than trying to reinvent the wheel.
jpm83
Quote from: Mark Hammer on December 13, 2007, 05:46:01 PM
Thanks Mark for that info. I Was planning this because reverb in my amp (Randall RG50TC) really sucks. Is that ggg stage center reverb how good and what it sounds like? And is there sound clips of stage center reverb anywhere?
Janne
