How did Analogman build this???
Started by aksman, December 18, 2007, 01:10:08 AM
aksman
How is this wired?   I want to try and put a single loop w/remote inside my "everything box" (the box that houses my power supplies, and input and output jacks).
this one would suffice too:
Do you have to use relays? or can you use passive electronics?  help?
Austin73
Don't know much about these products but I'm sure you'd either need a relay or go down the cmos switching route, but is that not using a sledgehammer for what it is ie a 2 loop true bypass switcher which I can make in the UK for about £12 instead of about £40 if I went all technical loL
If you want normal true bypass try any search and if you need cmos switching RG is always good to ask.
Sorry I can't be more help at mo.
AUS
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
analogmike
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
