Conductive pen
Started by Aren, December 26, 2007, 05:49:06 PM
Aren
Hi,
I tried searching the forum but did not see any final word on this. Has any one tried using a conductive pen in order to draw PCB traces on pad-per hole boards? Any reason why this should not be a good idea?
Pen - http://webtronics.stores.yahoo.net/2200-stp.html
Oren
Paul Perry (Frostwave)
The problems are 1. the expense of the pen and 2. the ink is not as conductive as solder or wire.
Papa_lazerous
you can get silver paint like nail varnish thats good for repairing traces, and also on the old AMD chips to unlock the multiplier ;)  mind you a graphite pencil was also good for that.  I wouldnt try using the conductive pen idea on anymore than a quick fix on something even then there is normally a better way.
runmikeyrun
i tried- pen's tip was too thick, it connected all the pads around it to each other.  Waste of $10 since i have not used it since.  I know how you feel though, it would have been way cool had it worked.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
stobiepole
I bought one, and it sucks...the stuff's too runny to use for anything small. Not good. And pricey.
Papa_lazerous
when I used one before and needed a thin trace, I had to put tape down on either side to screen what I didnt want to coat then go over the tape and the gap inbetween then wait for it to dry then remove tape, kinda a pain in the ass
