Made a parapedal
Started by Hanglow, January 03, 2008, 01:33:31 PM
Hanglow
Finally... I've been meaning to do this one for ages.
I made it on perfboard, using the smallest pcb layout that RG made, worked great first time. The only difference was using TL072's instead of the 4558's - thought it was a wee bit quieter.
I also tried lowering C4 to change the frequency range, but didn't like it, it wasn't pronounced enough. I will probably mess about with the values again in C2 and C4 to see if I can get any improvement, if there is anything to be had, although I really like it as it is.
I can't find my camera unfortunately,  :-[ so no gut shots.
I put it in one of these, a "weeper wah" /volume pedal that I bought new from cash generator for £10. The "wah" that I took out was truly one of the worst effects I have ever had the misfortune to use. However, it has proved useful!  I had previously tried to put an Idiot wah into it, but it didn't do anything for me - I probably messed it up.
Anyway, well worth a build if you have a spare wah/volume pedal kicking about - nails Electric Funeral :icon_mrgreen:
Valoosj
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
Paul Marossy
QuoteWhat the hell does it do?
It's like a wah pedal with massive huevos.  :icon_wink:
Hanglow
Very true  ;D
it has a huge sweep from basically a (very) low pass at heel down, through a kind of almost ring mod type sound to quite a high wah.  if you google Chicago Iron, they have some clips from their clone of it.
The only problem I have is that wah pedal doesn't have the same amount of travel as a normal one, so you have to be a bit more accurate/subtle with the foot.
joegagan
congrats hanglow, must've been fun to fire it up the first time
the clips i have heard of parapedal always made me smile
Hanglow
It sure was!  I have been particularly enjoying Dr Boogey>parapedal for outrageous distorted fun and parapedal>flatline for some nice smooth clean wah action.
Paul Marossy
If you run across a dead Maestro Boomerang, nab it - it has a longer travel and would probably work good for the Parapedal circuit.
Hanglow
Bump
Just a quick update - changed R12 (10K) to a 47k pot to see if I could change the depth of the wah as it is a bit brutal and therefore not quite as versatile as it could be - 47k was a bit pointless, ended up settling on a 2k4 resistor in series with a 10k lin pot . This gives it a good range from a smoother less deep wah to that ridiculous huge sweep that we all love  :icon_mrgreen: . A recommend mod I would say. Maybe even a 1k in series with the pot would be better.
Sweetalk
I'm looking to build a Parapedal, do you have some sound clips?
Congrats on your build
Hanglow
No unfortunately not  :(
but there are some here of chicago irons version, which give you a good idea what it is like
http://chicagoiron.com/audio/paraclnrcks.mp3
http://chicagoiron.com/audio/paraclns.mp3
http://chicagoiron.com/audio/spacemojo.mp3
If you do the R12 mod then the depth can be less
