A pre-amp vs. booster. Same thing?
Started by bipedal, January 29, 2008, 12:01:25 PM
bipedal
Maybe a silly question, but I don't know the answer, so I throw it out there for discussion.  Any categorical differences that distinguish one from another?
Both boost a signal - my best guess is that "pre-amp" implies greater tone shaping capabilities than "booster"...
- Jay
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
snoof
Generally speaking, you are correct.  For our purposes, they are pretty much the same thing.
Pushtone
Quote from: bipedal on January 29, 2008, 12:01:25 PM
- Jay
The term is used generally to mean many things, but to me the term "pre-amp" describes a device capable of amplifying a signal to line level. Or a device capable of driving a power amp to full output.
A booster, or any effect pedal is usually not capable of achieving line level.
But there are all kinds of" pre-amps"
For instance a unity gain preamp is still a preamp.
So many use the term to describe any type of low level amplifier that comes before the power amp section.
From one vantage point, the term "preamplifier" is applied to those circuits intended to bring a signal up to some expected level.  So, we have mic "preamps" because there is a huge gulf between normal vocal mic output levels and the anticipated level for line inputs.
In contrast, a "booster" is more or less what we think of when when referring to a circuit intended to bring the level of something up beyond expected or typical levels.  So, if I plug a voice mic into an LPB-1 and from there into a mixer, the LPB-1 is serving as a preamp.  If I were to plug a guitar into and LPB-1 and from there into the mic input on a mixer, the LPB-1 would be serving as a booster, and maybe even as an overdrive, depending on control settings.  Same amount of gain applied in both contexts, but that gain has different practical outcomes.
As for tone-shaping being a part of one but not the other, I think you are sort of onto something.  After all, phono-cartridge preamps such as one can (gasp! :icon_eek:) still buy at Radio Shack have only an input and output jack and an on-off switch.  At the same time, though, tone-shaping is an expected part of almost any piece of equipment intended to adapt a signal source to another piece of processing equipment that may or may not have the controls on board to compensate for whatever the booster or preamp does to the tone.
DougH
"preamp"- "booster"... They're just words.
No meaning whatsover in this context AFAIC...
