Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
NazzTazz
Quote from: gena_p1 on June 06, 2012, 03:11:58 AM
resistors are SMD mf, all other - with pins. film capacitors, etc.
First version had a single sided pcb, so if you interested,  - pm me.
as i posted previously:
back side: http://img-fotki.yandex.ru/get/5106/testo10.4/0_472e1_ebd85ba9_orig (i did several mistakes, cause of wrong re-drown schematic).
front side: http://img-fotki.yandex.ru/get/5300/testo10.4/0_472e0_4058c146_orig
http://img-fotki.yandex.ru/get/5801/testo10.5/0_4915b_7b73d647_orig
Wow, this PCB is so dense... Nice routing job.
midwayfair
Took a family portrait last night ...
In roughly the order they were built.
^ cool, happy little family they are too... 8)
gena_p1
seedlings
Well, this is my first 1590A, and YOU PEOPLE are freaking INCREDIBLE!!! These are small!  Here the toner/medium transfer is crooked, there are some paper fibers stuck on where I chickened out for fear of rubbing off more toner.  Captured a fingerprint in the extra 2 layers of gloss medium (dumb. should've just used lacquer).  LED Drill bit wandered...  BUT, you know, I really don't care.  Maybe the next will be better, maybe worse...
PnP Rangemaster with a few changes.
Thanks for your inspirations!
CHAD
dean owens
Quote from: roseblood11 on March 26, 2012, 04:30:59 AM
I wonder why these jacks aren't used more often in 1590A enclosures:
http://uk-electronic.de/onlineshop/product_info.php/cPath/50_22_24/products_id/1218/language/en?osCsid=ae42af714708c060ec08c8faa23d30bc
One reason could be because people can't find them in the states... at least I can't.  Anyone able to find them in the U.S.?
jimmybjj
Klon in a 1590a
Got all of the passives except one in the same direction :) I used all ceramics for polarized caps. made the mistake of not measuring the template i had in eagle and paid the price. As you can see in the top of the enclosure the cutouts are not deep enough which pushed the pcb down, luckily i was able to still make it fit  ::) Eagle files updated, that won't happen again. I've never used these type of jacks before didn't realize they were switching until it was wired up, next time i will have the i/o's switched to ground.
As usual crappy pic's don't do the pedals finish justice. Finished in DC texture powder coat. Embossed graphics. Aluminum knobs from smallbear. Background is actual beeswax that i use in my beekeeping adventures.
haveyouseenhim
@jimmy  that's great. good job. :o   Is that a double sided pcb?
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
seedlings
That Klon pedal is tight and glorious!
CHAD
Valoosj
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
My latest "squeeze":
Omega boost from runoffgroove.com.  Sounds sweet.  Most likely will get nicked by my tame guitarist.  Though the seemingly "nuclear fusion" LED may put him off...
haveyouseenhim
oh man    it blinded me through the screen :icon_lol: put some more resistance on that thing.   good work ;)   is that a sparkle yellow?
Sorry...  Here, try these:  :icon_cool:
I did calculate the correct resistor value, then I multiplied it by an order of magnitude, cos they always come out brighter than you need.  Looks like only one order of magnitude wasn't enough...   ;D
BTW, paint is a metallic copper enamel - not too obvious from the picture.  Not entirely happy with it.  I think it needs baking, despite the advice on the can...
dean owens
Has anyone ever attempted a Boss CS-3 (or even a CS-2) in one of these?  I looked through here but didn't see any.  If I could get a 1590a sized CS-3 then I could get my tuner back on my board which would be nice.
midwayfair
Quote from: dean owens on September 19, 2012, 02:14:20 PM
An etch with 1/8W resistors would probably fit, but you might have to cut the buffering. I'm pretty sure Mooer's comp is a CS-x. Most of their stuff is dead-on clones in a 1590A.
dean owens
Quote from: midwayfair on September 19, 2012, 03:04:20 PM
hmmm, I took a look at the Mooer.  I can't find it for sale anywhere but the info I can find on it says it's a CS-1.  From my understandings that is a different pedal from the 2 and 3 versions.  I guess I'll wait until it comes out and see what the talk of the town is.
As to the other stuff... I thought I might have to lose the buffer but that's not so bad.  Can you tell me what you mean by "etch"?  Are you referring to etching my own board?
danielzink
layout from over at FSB....
My very first ever vero build.
The tone control is definitely subtle.....
Probably could've come up with a more creative name - but I wanted to get it boxed up and on the board asap.
Actually works very well pushing a tube amp into a nice crisp overdrive.
mg.audio
my first 1590A project, a slightly modified Shin-Ei Companion Fuzz:
