Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Perrow
I remember people saying they drilled through the pot shaft, and others saying they've found pots "pre drilled" shafts.
haveyouseenhim
Quote from: therealfindo on December 17, 2013, 06:50:18 AM
I'm guessing it's a pot with a built-in LED.. I've been looking for them, but haven't found a supplier yet.
It's a clear plastic pot shaft. Smallbear has em in stock.
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
midwayfair
Havaden
Thanks a lot guys!
I've already bought a lot of 12mm, and just came up with the idea of squeezing a few flat sanded 3 mm LEDs underneath the pot with some sort of plastic washer to insulate it all.  ::)
I finished drilling the 1590a tremolo at school today, turned out great :D
and I'll post the pics of my horrific wiring and paintjob once painting is possible, the weather is just to cold for it right now :(
It's not always easy, but it's never impossible :D
Gibson SG Special worn brown 2006 (W. Bigsby b3)
Squier bullet fiesta red 2009 with a ton of care and mods.
Chibson LP Custom 2015 (Fixed broken neck)
Gibson LP Junior 2009
Havaden
Quote from: peterg on November 28, 2013, 05:47:47 PM
Does anyone care to share their 1590A drilling templates?
I just finished my V.2 template, or more a measurement note.
On the next one i will lower both jacks 5mm towards the 3DPT since i noticed that the side of my jacks will fit nicely between the switch and the side of the box.
Now i don't know if this one will work for you, but it works just fine for me ;)
i use the standard open metal/fiberglass jacks, 3DPT and 12mm pots.
I use this dc jack:
if you don't use batteries (unlikely in a 1590a) use an 8mm dc socket instead of those massive 18mm holes..... save a little more space.. :)
Havaden
Quote from: deadastronaut on December 17, 2013, 12:52:53 PM
Learned from the first build that every millimeter counts  :icon_eek:
I don't mind the 12mm pots, but those 18mm sockets forces the circuitboard to be a lot smaller.
thanks for the hint, i will need it for my upcoming 1590a little angel :D
yeah every mm counts with those little buggers..
i think most of the dainty footed guys use 9mm pots too. ;D
Perrow
Quote from: Havaden on December 17, 2013, 01:04:49 PM
My first 1590A, EVERY millimeter counted.
http://rumbust.net/Superfly+in+a+1590A
^ man those tubes must be tiny as f... 8)
do they glow at all, or leds?..
therealfindo
Will have ask one of my German shop-keepers if they can get those clear-shaft pots in
Perrow
Quote from: deadastronaut on December 18, 2013, 05:06:56 AM
They're about AA sized, I'll post a pic later. There's not a lot of glow, but yes, they glow.
Perrow
Damn, I always forget how stupidly small these guys are. I held that amp in my hand something like two days ago and still I was off by a factor of about two on the size.
blimey that is tiny, might as well of used fets ;D
thelonious
Perrow
Quote from: deadastronaut on December 18, 2013, 12:24:23 PM
Well, I did, 'twas getting two fets and a led inside each glass "shell" that was hard  :icon_mrgreen:
Havaden
That is one tiny amp and some really tiny tubes ! :D
tubegeek
Perrow, is that a Fender reverb driver transformer? Where did you get that particular one?
joelster
Perrow, that is amazing! How's it sound?
This is actually a re-working of a pedal that I had already finished. It's a Rat with a switchable Reutz Mod:
